楼主: Walker
到目前为止适合最新版本的17.2.4的注册补丁
发表于 2018-2-11 18:24:00 | 显示全部楼层
这个是最新的版本么?
发表于 2018-2-11 17:08:26 | 显示全部楼层
xie xie fen xiang
发表于 2018-2-11 17:02:38 | 显示全部楼层
看看17.2.5能不能用
发表于 2018-2-11 14:54:58 | 显示全部楼层
楼主,破解不了呀,还是提示这是试用版,只不过使用时间有6000多天。求解……
弹出试用版提示
弹出试用版提示
发表于 2018-2-11 13:37:30 | 显示全部楼层
need  this,thx.
发表于 2018-2-11 13:01:28 | 显示全部楼层
thanks for sharing
22 小时
发表于 2018-2-11 11:24:39 | 显示全部楼层
thanks for sharing
发表于 2018-2-11 09:29:35 | 显示全部楼层
注册方法还是一样吗?
发表于 2018-2-11 08:50:47 | 显示全部楼层
非常好资源,谢谢
102 小时
发表于 2018-2-11 08:43:38 | 显示全部楼层
试试看能否破解
发表于 2018-2-10 22:54:43 | 显示全部楼层
多谢楼主分享
15 小时
发表于 2018-2-10 21:38:57 | 显示全部楼层
  非常感谢分享,正好需要
发表于 2018-2-10 19:55:52 | 显示全部楼层
感谢楼主分享
发表于 2018-2-10 19:17:50 | 显示全部楼层
测试ceshixiaoguo
16 小时
发表于 2018-2-10 16:39:05 | 显示全部楼层
支持了,感谢先
37 小时
发表于 2018-2-10 13:53:00 | 显示全部楼层
好东西,一定要及时分享.
20 小时
发表于 2018-2-10 10:26:07 | 显示全部楼层
好,谢谢
35 小时
发表于 2018-2-9 17:30:30 | 显示全部楼层
看看是否可用
44 小时
发表于 2018-2-9 15:00:15 | 显示全部楼层
PDF Processing (Common)
T580681 - Export to PDF - The bullet character is incorrectly exported when AzureCompatibility is enabled
T587796 - Export to PDF - The content of a control that is cropped in the invisible area should not be exported
T596796 - JBIG - Images with the 'page default pixel value' equal to 1 are decoded incorrectly
T596843 - Parsing - A document containing a rectangle with coordinates represented as indirect objects cannot be opened
T591375 - Parsing - A document containing a signature reference dictionary with an invalid 'Data' key value cannot be opened
T595875 - Parsing - A document containing the '%' character before the PDF version token cannot be opened
T593103 - Parsing - A document containing the signature build data dictionary with the 'Name' value represented as a string cannot be opened
T587707 - Parsing - Documents containing a signature reference dictionary with an incorrect "DigestMethod" key cannot be opened
T589984 - Parsing - Documents containing an optional content group without the "Name" key cannot be opened
T597591 - Parsing - Documents containing invalid print page ranges cannot be opened
T588259 - Parsing - Documents containing streams with the "Length" key that refers to a non-existing object are processed incorrectly
T598120 - Rendering - A document containing the corrupted ICC profile cannot be rendered
T597714 - Rendering - A page with content stream containing a real number with incorrect representation is rendered incorrectly
T590427 - Rendering - Documents containing non-embedded 'GothicText' and 'Flama' fonts are rendered incorrectly
T597169 - Rendering - Documents containing Type 1 fonts with invalid PostScript operators cannot be rendered
T595740 - Rendering - Text drawn by the TrueType font with cmap containing only segmented coverage mapping cannot be rendered
T588769 - Text Extraction - Text is incorrectly extracted from documents containing character glyphs named according to the "uniXXXX" pattern
T590034 - Text Extraction - Text is incorrectly extracted from documents containing simple fonts with an empty "ToUnicode" mapping
T596321 - Writing - A document containing a name tree with collisions cannot be processed
32 小时
发表于 2018-2-9 14:51:48 | 显示全部楼层
发表于 2018-2-9 13:54:59 | 显示全部楼层
谢谢楼主,下载了试一下
发表于 2018-2-9 13:20:23 | 显示全部楼层
大神,感谢的不要不要的
GMT+8, 2025-4-4 19:56
