查看: 5424|回复: 0
【教程】关于SpreadsheetControl和RichEditControl的CommandService的用法
4481 小时
黄马甲
发表于 2018-3-30 17:09:23 | 显示全部楼层 |阅读模式
我们在使用SpreadsheetControl或者RichEditControl的时候可能会需要对此类控件的系统事件做一些定制和干预,比如我们需要在文档保存前判断一下文档内容的大小,或者在文件打开的判断一下内容是否包含某些敏感词等等,该如何操作呢?
这时候我们就需要用到它们各自的CommandService了,话不多说,直接上代码!
SpreadsheetControl:
public static class MyCommandHelper
    public static void SetMyNewCommandFactory(SpreadsheetControl control)
        ISpreadsheetCommandFactoryService service = (ISpreadsheetCommandFactoryService)control.GetService(typeof(ISpreadsheetCommandFactoryService));
        CustomService customService = new CustomService(service);
        control.ReplaceService<ISpreadsheetCommandFactoryService>(customService);
        customService.Control = control;
public class CustomService : SpreadsheetCommandFactoryServiceWrapper
    public CustomService(ISpreadsheetCommandFactoryService service) : base(service) { }
    public SpreadsheetControl Control { get; set; }
    public override SpreadsheetCommand CreateCommand(SpreadsheetCommandId id)
        if (id == SpreadsheetCommandId.FileSave)
            return new CustomSaveDocumentCommandCommand(Control);
        return base.CreateCommand(id);
public class CustomSaveDocumentCommandCommand : SaveDocumentCommand
    public CustomSaveDocumentCommandCommand(ISpreadsheetControl control) : base(control) { }
    protected override void ExecuteCore()
        if (Control.ActiveSheet.Name == "test")
            MessageBox.Show("表名不合法不让保存!", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
        else
            base.ExecuteCore();
//调用:
MyCommandHelper.SetMyNewCommandFactory(spreadsheetControl1);
RichEditControl:
    public static void SetMyNewCommandFactory(RichEditControl control)
        var myCommandFactory = new CustomRichEditCommandFactoryService(control, control.GetService<IRichEditCommandFactoryService>());
        control.ReplaceService<IRichEditCommandFactoryService>(myCommandFactory);
public class CustomRichEditCommandFactoryService : IRichEditCommandFactoryService
    readonly IRichEditCommandFactoryService service;
    readonly RichEditControl control;
    public CustomRichEditCommandFactoryService(RichEditControl control,
        IRichEditCommandFactoryService service)
        this.control = control;
        this.service = service;
    public RichEditCommand CreateCommand(RichEditCommandId id)
        if (id == RichEditCommandId.FileSave)
            return new CustomSaveDocumentCommand(control);
        return service.CreateCommand(id);
public class CustomSaveDocumentCommand : SaveDocumentCommand
    public CustomSaveDocumentCommand(IRichEditControl control) : base(control) { }
    protected override void UpdateUIStateCore(ICommandUIState state)
        base.UpdateUIStateCore(state);
        state.Enabled = Control.Document.Paragraphs.Count < 7;
        if (Control.Document.Paragraphs.Count > 7)
            MessageBox.Show("段落太多不让保存!", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
        else
            base.ExecuteCore();
//调用:
MyCommandHelper.SetMyNewCommandFactory(richEditControl1);
大家还可以通过判断它们各自的CommandId来实现不同的功能干预。是不是很简单呢?
GMT+8, 2025-1-22 20:56
