- 42
- 11 小时
- 1
- 2015-1-2
- 18
- 2024-6-4
- 18
- 170
- 11 小时
- 2015-1-2
using System;
using System.Data;
using System.Data.Common;
using System.Data.Odbc;
using System.Data.OleDb;
using System.Data.OracleClient;
using System.Data.SqlClient;
using System.Data.SQLite;
using MySql.Data.MySqlClient;
using System.Text;
namespace SXLibrary
public enum DBType
/// SQL Server数据库
SQLServer,
/// Access类型数据库 string conStr = "Provider=Microsoft.Jet.OleDb.4.0;Data Source=E:\数据库\XiaoZhen.mdb;"
OleDb,
/// ODBC数据源 string conStr = "DSN=XXX;uid=sa;pwd=sa;"
ODBC,
/// Oracle数据库
Oracle,
/// MySQL
MySQL,
/// SQLite Data Source={0};Pooling=true; FailIfMissing=false;
SQLite
/// 2014年4月22日18:22:28 思信软件 崔
/// 通用数据库访问类 DBHelper类,
/// 支持SQL Server、OleDb、ODBC、Oracle、MySQL、SQLite等
/// 不同类型的数据源
public class DBHelper : IDisposable
/// 该枚举类型用于枚举数据库的类型
#region 初始化数据库工厂
private DBType _DatabaseType = DBType.SQLServer;
private DbProviderFactory provider = null;
/// 获取数据库类型属性
public DBType DatabaseType
get { return _DatabaseType; }
private string _ConnectionString = "";
/// 获取数据库连接字符串属性
public string ConnectionString
get { return _ConnectionString; }
/// 构造函数,默认数据库是SQL Server
public DBHelper(string ConString)
this._DatabaseType = DBType.SQLServer;
this._ConnectionString = ConString;
GetProvider();
/// 构造函数
/// <param name="ConString">数据库连接字符串</param>
/// <param name="DbType">访问的数据库类型</param>
public DBHelper(string ConString, DBType DbType)
this._DatabaseType = DbType;
GetProvider();
/// 根据数据库类型获取数据库实例
/// <returns></returns>
private void GetProvider()
switch (this.DatabaseType)
case DBType.SQLServer:
provider = SqlClientFactory.Instance;
break;
case DBType.OleDb:
provider = OleDbFactory.Instance;
break;
case DBType.ODBC:
provider = OdbcFactory.Instance;
break;
case DBType.Oracle:
provider = OracleClientFactory.Instance;
break;
case DBType.MySQL:
provider = MySqlClientFactory.Instance;
break;
case DBType.SQLite:
provider = SQLiteFactory.Instance;
break;
default:
break;
#endregion
#region ExecuteNonQuery
/// 执行SQL语句并返回受影响的行的数目
/// <param name="cmdText">数据库命令字符串</param>
/// <returns>受影响的行的数目</returns>
public int ExecuteNonQuery(string cmdText)
return ExecuteNonQuery(cmdText, CommandType.Text, null);
/// <param name="cmdType">命令执行方式</param>
public int ExecuteNonQuery(string cmdText, CommandType cmdType)
return ExecuteNonQuery(cmdText, cmdType, null);
/// <param name="ParametersList">参数</param>
public int ExecuteNonQuery(string cmdText, Dictionary<string, object> ParametersList)
return ExecuteNonQuery(cmdText, CommandType.Text, ParametersList);
public int ExecuteNonQuery(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
int val = -1;
using (DbConnection conn = provider.CreateConnection())
var cmd = conn.CreateCommand();
PrepareCommand(conn, cmd, cmdText, cmdType, ParametersList);
try
val = cmd.ExecuteNonQuery();
catch (Exception ex)
WriteExLog(ex, cmdText, ParametersList);
throw ex;
return val;
#endregion
#region ExecuteReader
/// 执行SQL语句并返回数据行
/// <returns>数据读取器接口</returns>
public IDataReader ExecuteReader(string cmdText)
return ExecuteReader(cmdText, CommandType.Text, null);
/// 执行SQL语句并返回数据行
public IDataReader ExecuteReader(string cmdText, CommandType cmdType)
return ExecuteReader(cmdText, cmdType, null);
/// 执行SQL语句并返回数据行
public IDataReader ExecuteReader(string cmdText, Dictionary<string, object> ParametersList)
return ExecuteReader(cmdText, CommandType.Text, ParametersList);
/// 执行SQL语句并返回数据行
public IDataReader ExecuteReader(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
IDataReader reader = null;
try
reader = cmd.ExecuteReader(CommandBehavior.CloseConnection);
throw ex;
return reader;
#endregion
#region GetOneResult
/// 执行SQL语句并返回单值对象
/// 即结果集中第一行的第一条数据
/// <returns>单值对象-结果集中第一行的第一条数据</returns>
public object GetOneResult(string cmdText)
return GetOneResult(cmdText, CommandType.Text, null);
/// 执行SQL语句并返回单值
/// 即结果集中第一行的第一条数据
public string GetOneString(string cmdText)
string str = "";
var res = GetOneResult(cmdText, CommandType.Text, null);
if (res != null) { str = res.ToString(); }
return str;
/// 执行SQL语句并返回单值对象
/// 即结果集中第一行的第一条数据
public object GetOneResult(string cmdText, CommandType cmdType)
return GetOneResult(cmdText, cmdType, null);
/// 执行SQL语句并返回单值
/// 即结果集中第一行的第一条数据
public string GetOneString(string cmdText, CommandType cmdType)
string str = "";
var res = GetOneResult(cmdText, cmdType, null);
return str;
/// 执行SQL语句并返回单值对象
/// 即结果集中第一行的第一条数据
public object GetOneResult(string cmdText, Dictionary<string, object> ParametersList)
return GetOneResult(cmdText, CommandType.Text, ParametersList);
public object GetOneResult(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
object obj = null;
try
obj = cmd.ExecuteScalar();
StringBuilder sblog = new StringBuilder();
sblog.Append(ex.Message System.Environment.NewLine);
sblog.Append("CommandText: " cmdText System.Environment.NewLine);
if (ParametersList != null)
foreach (var item in ParametersList)
sblog.Append("Params: " item.Key " = " item.Value.ToString() System.Environment.NewLine);
SXLibrary.Log.WriteExLog(sblog.ToString(), typeof(DBHelper));
throw ex;
return obj;
#endregion
#region GetDataSet
/// 填充一个数据集对象并返回之
/// <returns>数据集对象</returns>
public DataSet GetDataSet(string cmdText)
return GetDataSet(cmdText, CommandType.Text, null);
/// 填充一个数据集对象并返回之
public DataSet GetDataSet(string cmdText, CommandType cmdType)
return GetDataSet(cmdText, cmdType, null);
/// 填充一个数据集对象并返回之
public DataSet GetDataSet(string cmdText, Dictionary<string, object> ParametersList)
return GetDataSet(cmdText, CommandType.Text, ParametersList);
/// 填充一个数据集对象并返回之
private DataSet GetDataSet(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
DataSet ds = new DataSet();
DbDataAdapter da = provider.CreateDataAdapter();
da.SelectCommand = cmd;
try
da.Fill(ds);
throw ex;
return ds;
#endregion
#region GetDataTable
/// 填充一个数据表对象并返回之
/// <returns>数据表对象</returns>
public DataTable GetDataTable(string cmdText)
return GetDataTable(cmdText, CommandType.Text, null);
/// 填充一个数据表对象并返回之
public DataTable GetDataTable(string cmdText, CommandType cmdType)
return GetDataTable(cmdText, cmdType, null);
/// 填充一个数据表对象并返回之
public DataTable GetDataTable(string cmdText, Dictionary<string, object> ParametersList)
return GetDataTable(cmdText, CommandType.Text, ParametersList);
/// 填充一个数据表对象并返回之
public DataTable GetDataTable(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
DataTable dt = new DataTable();
try
da.Fill(dt);
throw ex;
return dt;
#endregion
#region GetOneDataRow
/// 填充一个DataRow对象并返回之
public DataRow GetOneDataRow(string cmdText)
var dt = GetDataTable(cmdText, CommandType.Text, null);
return dt.Rows.Count == 0 ? null : dt.Rows[0];
public DataRow GetOneDataRow(string cmdText, CommandType cmdType)
var dt = GetDataTable(cmdText, cmdType, null);
/// <param name="ParametersList">ParametersList</param>
public DataRow GetOneDataRow(string cmdText, Dictionary<string, object> ParametersList)
var dt = GetDataTable(cmdText, CommandType.Text, ParametersList);
public DataRow GetOneDataRow(string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
var dt = GetDataTable(cmdText, cmdType, ParametersList);
#endregion
#region ExecuteProcedure
/// 执行带返回参数的存储过程
/// <param name="ProcedureName">存储过程名</param>
/// <param name="spl">参数列表</param>
public Dictionary<string, object> ExecuteProcedure(string ProcedureName, DbParameter[] ParametersList)
Dictionary<string, object> dc = new Dictionary<string, object>();
try
cmd.CommandText = ProcedureName;
cmd.CommandType = CommandType.StoredProcedure;
cmd.Parameters.AddRange(ParametersList);
if (item.Direction == ParameterDirection.Output)
dc.Add(item.ParameterName, cmd.Parameters[item.ParameterName].Value);
return dc;
WriteExLog(ex, ProcedureName, ParametersList);
throw ex;
#endregion
/// 执行多条Sql命令(包含事務功能)
/// <param name="cmdTextList">Sql命令数组</param>
/// <returns>正确执行返回True,错误执行为False</returns>
public bool ExecuteSqlList(List<string> cmdTextList)
bool flag = false;
conn.ConnectionString = ConnectionString;
conn.Open();
cmd.CommandType = CommandType.Text;
var tx = conn.BeginTransaction();
cmd.Transaction = tx;
try
foreach (string sql in cmdTextList)
cmd.CommandText = sql;
tx.Commit();
flag = true;
tx.Rollback();
SXLibrary.Log.WriteExLog(ex.Message.ToString(), typeof(DBHelper));
throw ex;
return flag;
private List<KeyValuePair<string,DbParameter[]>> TransactionList;
public void AddToTransaction(string cmdText, Dictionary<string, object> ParametersList)
if (TransactionList == null)
{ TransactionList = new List<KeyValuePair<string,DbParameter[]>>(); }
List<DbParameter> LP = new List<DbParameter>();
var param = provider.CreateParameter();
param.ParameterName = item.Key;
param.Value = item.Value;
LP.Add(param);
DbParameter[] dbp= null;
if (LP.Count > 0)
dbp = LP.ToArray();
KeyValuePair<string, DbParameter[]> kvp = new KeyValuePair<string, DbParameter[]>(
cmdText,dbp
TransactionList.Add(kvp);
/// ExecuteTransaction 需要先AddToTransaction
public bool ExecuteTransaction()
bool flag = false;
if (TransactionList == null || TransactionList.Count == 0)
return false;
conn.Open();
try
foreach (var item in TransactionList)
cmd.CommandText = item.Key;
cmd.Parameters.AddRange(item.Value);
cmd.Parameters.Clear();
tx.Commit();
flag = true;
tx.Rollback();
throw ex;
finally {
TransactionList.Clear();
return flag;
#region PrepareCommand
/// 准备执行命令
/// <param name="conn">DbConnection</param>
/// <param name="cmd">DbCommand</param>
/// <param name="cmdText">sql命令字符串</param>
/// <param name="cmdType">执行方式</param>
private void PrepareCommand(DbConnection conn, DbCommand cmd, string cmdText, CommandType cmdType, Dictionary<string, object> ParametersList)
if (conn.State == ConnectionState.Closed)
conn.Open();
cmd.CommandText = cmdText;
cmd.CommandType = cmdType;
foreach (var p in ParametersList)
var dp = cmd.CreateParameter();
dp.ParameterName = p.Key;
dp.Value = p.Value;
cmd.Parameters.Add(dp);
/// 准备执行一个命令
/// <param name="conn">OleDb连接</param>
/// <param name="cmd">sql命令</param>
/// <param name="trans">OleDb事务</param>
/// <param name="cmdType">命令类型例如 存储过程或者文本</param>
/// <param name="cmdText">命令文本,例如:Select * from Products</param>
/// <param name="cmdParms">执行命令的参数</param>
SqlTransaction trans, CommandType cmdType,
string cmdText, DbParameter[] cmdParms)
if (conn.State != ConnectionState.Open)
{ conn.Open(); }
cmd.Connection = conn;
if (trans != null)
{ cmd.Transaction = trans; }
if (cmdParms != null)
foreach (var parm in cmdParms)
cmd.Parameters.Add(parm);
#endregion
private void WriteExLog(Exception ex, string cmdText, Dictionary<string, object> ParametersList)
private void WriteExLog(Exception ex, string cmdText, DbParameter[] ParametersList)
sblog.Append("Params: " item.ParameterName " = " item.Value.ToString() System.Environment.NewLine);
#region Dispose
/// 释放资源
public void Dispose()
//好像没啥可释放的了,conn用了using 。
#endregion
