查看: 3460|回复: 0
[讨论] 求助与交流,用函数替代do……while() 循环功能
发表于 2018-7-20 15:01:36 | 显示全部楼层 |阅读模式
运行以下代码出错
(double V1, double V2) solve(double Va, double Vb)
//x1,x2,alpha,beta 是函数外部的常数值,Ea,Eb是自定义类的一个实例,取值没问题
                double Va1 = Va;
                double Vb1 = Vb;
                double Cas = x1 * Va / (x1 * Va + x2 * Vb);
                double Cbs = x2 * Vb / (x1 * Va + x2 * Vb);
                Va = alpha* (1.0 + Ea.u * Cbs ) * (Ea.Phi - Eb.Phi));
                Vb = beta * (1 + Eb.u * Cas ) * (Eb.Phi - Ea.Phi));
                if (Va == Va1 && Vb == Vb1)
                    return (Va, Vb);
                else
                    DateTime stop = DateTime.Now; //获取代码段执行结束时的时间
                    TimeSpan tspan = stop - start;
                    if (tspan.TotalMilliseconds > 10000)
                        return (Va, Vb);
                    else
                        return solve(Va, Vb);
错误提示如下:
System.StackOverflowException
  HResult=0x800703E9
  Source=<无法计算异常源>
  StackTrace:
<无法计算异常堆栈跟踪>
相反,改用do……while 循环时运行正常,请大神们帮忙分析分析问题出在哪,谢谢!
GMT+8, 2025-4-20 21:46
