- 362
- 99 小时
- 8
- 2015-6-25
- 99
- 2025-3-14
- 99
- 1072
- 99 小时
- 2015-6-25
Aspose.Cells 的注册破解 以及基本操作 求赞
https://pan.baidu.com/s/11iBWdTxX2twqg7J4BxclEQ 密码:fx8g
System.IO.MemoryStream objImage;
System.Net.WebClient objwebClient;
string sURL = "http://127.0.0.1/1575C.jpg";
objwebClient = new System.Net.WebClient();
objImage = new System.IO.MemoryStream(objwebClient.DownloadData(sURL));
Aspose.Cells.Workbook wb = new Aspose.Cells.Workbook();
Aspose.Cells.Worksheet sheet = wb.Worksheets[0];
Aspose.Cells.Drawing.PictureCollection pictures = sheet.Pictures;
pictures.Add(0, 0,3,3 ,objImage);
wb.Save("d:\\sysdata\\webimagebook.xls");
/// <param name="e"></param>
private void button3_Click(object sender, EventArgs e)
Aspose.Cells.Workbook wb = new Aspose.Cells.Workbook("D://Sysdata//1234.xls");
Aspose.Cells.Worksheet sheet = wb.Worksheets["Sheet1"];
Cells cells = sheet.Cells;
int StartRow = 1; //复制开始行
int DestinRow = 4; // 粘贴开始行
int TotalRows = 3; //总行数
sheet.Cells.CopyRows(cells, StartRow, DestinRow, TotalRows);
wb.Save("D://Sysdata//1234.xls");
MessageBox.Show("保存完成");
/// 格式设置
private void button5_Click(object sender, EventArgs e)
Style style = CreateAsponeStyle(wb);
sheet.Cells[11, 2].PutValue("九五智障");
sheet.Cells[11, 2].SetStyle(style);
MessageBox.Show("执行完成");
/// 创建单元格格式
/// <param name="wb"></param>
/// <returns></returns>
public Style CreateAsponeStyle(Workbook wb)
Style style = wb.CreateStyle();
//设置居中
style.HorizontalAlignment = Aspose.Cells.TextAlignmentType.Center;
//设置背景颜色
style.ForegroundColor = System.Drawing.Color.FromArgb(153, 204, 0);
//单元格的线:实线
style.Pattern = Aspose.Cells.BackgroundType.Solid;
//字体居中
//文字字体
style.Font.Name = "宋体";
//文字大小
style.Font.Size = 36;
//单元格内容自动换行
style.IsTextWrapped = true;
//粗体
style.Font.IsBold = false;
//应用边界线 左边界线
style.Borders[BorderType.LeftBorder].LineStyle = CellBorderType.Thin;
//应用边界线 右边界线
style.Borders[BorderType.RightBorder].LineStyle = CellBorderType.Thin;
//应用边界线 上边界线
style.Borders[BorderType.TopBorder].LineStyle = CellBorderType.Thin;
//应用边界线 下边界线
style.Borders[BorderType.BottomBorder].LineStyle = CellBorderType.Thin;
return style;
* Date:2018-05-21 15:37:06
* Memo:Aspose.Cells.dll 使用
public static class AsposeCellsReadWrite
///string
/// <param name="dt"></param>
/// <param name="dtExcel"></param>
/// <param name="dic"></param>
public static void StringDictionaryMatching(DataTable dt, DataTable dtExcel, Dictionary<string, string> dic)
foreach (var kv in dic)
dt.Rows[0][kv.Key] = string.IsNullOrEmpty(dtExcel.Rows[0][kv.Value].ToString())
? dt.Rows[0][kv.Key]
: dtExcel.Rows[0][kv.Value].ToString();
/// 注册dll
public static void RegisterAsposeCell()
Aspose.Cells.License li = new Aspose.Cells.License();
string licPath = Application.StartupPath + "\\License.lic";
li.SetLicense(licPath);
/// 读取Excel
/// <param name="sPath">路径</param>
/// <param name="sheetName">页签名称</param>
/// <param name="StartRow">开始行</param>
/// <param name="StartColumn">开始列</param>
public static DataTable AsposeCellsReadExcel(string sPath,string sheetName,int StartRow,int StartColumn )
RegisterAsposeCell();
Workbook book = new Workbook(sPath);
Worksheet sheet = book.Worksheets[sheetName];
DataTable dt = cells.ExportDataTableAsString(0, 0, cells.MaxDataRow + 1, cells.MaxDataColumn + 1, true);
return dt;
/// 读取Excel
/// <param name="EndColumns">结束行</param>
/// <param name="StartColumn">结束列</param>
public static DataTable AsposeCellsReadExcel(string sPath, string sheetName, int StartRow,int endRows, int EndColumns, int StartColumn)
DataTable dt = cells.ExportDataTableAsString(0, 0,endRows ,EndColumns, true);
return dt;
/// Excel中数据为空 不清空数据库
public static void DataDictionaryMatching(DataTable dtSever, DataTable dtExcel, Dictionary<string, string> dic)
dtSever.Rows[0][kv.Key] = string.IsNullOrEmpty(dtExcel.Rows[0][kv.Value].ToString())
? dtSever.Rows[0][kv.Key]
