查看: 4045|回复: 1
[求助] Setup Project專案內使用Silent Mode執行InstallShield安裝包會有問...
发表于 2018-8-27 22:33:39 | 显示全部楼层 |阅读模式
各位大神們好,
小弟最近在用Setup Project打包程式,稱呼為A。
其中因為專案需求,我必須在A的安裝過程中安裝一個InstallShield打包的安裝包B,
在this.AfterInstall及this.BeforeUninstall的部份分別加入了「安裝」及「反安裝」B的代碼,
不過卻無法順利執行,B產生的setup.log得到的ResultCode=-3,但原因不明…
懇請板上大神協助,這個問題困擾小弟好久,一直無法解決阿…謝謝!!
下述代碼中,InstallerHelper_AfterInstall及 InstallerHelper_BeforeUninstall內的代碼,分別放在新建立的C# console程式中,卻能正常運行,
且WaitforExit()也能順利卡住,而B安裝包也能順利執行,ResultCode=0。
代碼如下:
using System;
using System.Collections;
using System.ComponentModel;
using System.Configuration.Install;
using System.Linq;
using System.Threading.Tasks;
using System.Configuration;
using System.Windows;
using System.IO;
using System.Diagnostics;
using System.Threading;
namespace FRWebService
    [RunInstaller(true)]
    public partial class InstallerHelper : Installer
        public InstallerHelper()
            InitializeComponent();
            this.BeforeInstall += new InstallEventHandler(InstallerHelper_BeforeInstall);
            this.AfterInstall += new InstallEventHandler(InstallerHelper_AfterInstall);
            this.BeforeUninstall += new InstallEventHandler(InstallerHelper_BeforeUninstall);
            this.AfterUninstall += new InstallEventHandler(InstallerHelper_AfterUninstall);
        private void InstallerHelper_BeforeUninstall(object sender, InstallEventArgs e)
            try
                String arg = "/s /uninst";
                Process p = Process.Start("C:\\Program Files\\Test\\setup_io.exe", arg);
                p.WaitForInputIdle();
                p.WaitForExit();
            catch (Exception ex)
        private void InstallerHelper_BeforeInstall(object sender, InstallEventArgs e)
        private void InstallerHelper_Committing(object sender, InstallEventArgs e)
        private void InstallerHelper_Committed(object sender, InstallEventArgs e)
        private void InstallerHelper_AfterInstall(object sender, InstallEventArgs e)
            try
                String arg = "/s";
                p.WaitForExit();
        private void InstallerHelper_AfterUninstall(object sender, InstallEventArgs e)
        //Code to perform at the time of installing application
        public override void Install(System.Collections.IDictionary stateSaver)
            System.Diagnostics.Debugger.Launch();
            base.Install(stateSaver);
            System.Windows.Forms.MessageBox.Show("Installing Application...");
        public override void Uninstall(System.Collections.IDictionary stateSaver)
            base.Uninstall(stateSaver);
            System.Windows.Forms.MessageBox.Show("Uninstalling Application...");
 楼主| 发表于 2018-9-3 09:49:14 | 显示全部楼层
以下更新一下進度… 請大神幫幫忙呀
1.
setup.log的內容只有這樣
[ResponseResult]
ResultCode=-3
2.
Setup Project會產生兩個檔案,一個是msi,一個是exe,我嘗試用管理員身份運行該exe,但也是無法…
P.S. 目前試過能成功的部份是…AfterInstall時運行B安裝包,但是不要用WaitForExit的話,就能順利靜默安裝… 不過因為B安裝包裝完我還要做一些操作...
GMT+8, 2025-4-20 16:50
