查看: 9704|回复: 3
Crack is not working for 18.2.3 version
443 小时
发表于 2018-11-14 21:06:14 | 显示全部楼层 |阅读模式
Hello !
I have installed Devexpress 18.2.3 , with Visual studio 2017 and after i've applied the Patch 8.0.
It seems to work , but after 2 days i have this error message :
You have installed DevExpress Products in Evaluation Mode - To purchase a license, please visit us online at: www.devexpress.com/purchase.
If you've purchased DevExpress Products and need to register your license, please review: www.devexpress.com/Support/Center/KB/p/K18106.aspx.
32 小时
发表于 2018-11-14 22:44:50 | 显示全部楼层
破解失效了?我用的挺好的呀,如果不行建议使用稍低一点的版本,最新版本的破解可能不稳定。
443 小时
 楼主| 发表于 2018-11-15 08:57:04 | 显示全部楼层
abc35277 published in 2018-11-14 22:44
The crack is invalid? I used it very, if not. It is recommended to-slightly lower version, and the latest version of the hack may unstable. ...
Windows 10-build 17134
VS 2017 Pro
devexpress 18.2.3
Patch Dimaster V8
winforms = Working but Trial Version in Designer
wpf-working,  Trial Version in Designer
Webforms = Wo rking and Trial Version at Designer
Reporting = Not Working (watermark:this application is created using the Tri Al version of the Xtrareports)
32 小时
发表于 2018-11-16 01:02:58 | 显示全部楼层
The crack is invalid? I used it very, if not. It is recom ...
at present,the version 18.2.3 is not have a perfact crack
I mean replacing low version software and use this crack file(DevExpressPatch 8.0 for Visual Studio 2017).
The trial Version notice maybe use a system registry file to solve.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Licenses\BAA304DF-1198-4BB5-AFCB-14801F755AA6]
"181ASP.NET"=dword:00000001
"181WPF Components"=dword:00000001
"181Windows Forms"=dword:00000001
this is 18.1.x
我觉得我还是说中文方便点。
1、18.2.3版本目前应该没有一个完美的破解。
2、我之前的意思是建议您使用低一点的版本,比如说:18.1.7(最后一个支持framework4的版本)
3、修改注册表可以解决使用lisence文件的问题但是打开项目时仍然可能会有提示,之后就不会有提示了。
4、您说的在设计器提示试用的直接原因是lisence在properties下被编译的原因,你可以选择把lisence的编译属性设为无。
GMT+8, 2025-4-18 13:12
