查看: 4837|回复: 1
[源码] C# 各种加密/解密方式和Base64编码/解码
发表于 2019-1-27 11:03:40 | 显示全部楼层 |阅读模式
  • MD5加密
  • DES加密/解密
  • SHA1加密
  • RSA加密/解密
  • AES加密/解密
  • Base64编码/解码
  • RSA-SHA1 数字签名
using System;
using System.Collections;
using System.Data;
using System.Linq;
using System.Reflection;
using System.Text;
using System.Security.Cryptography;
using System.IO;
namespace Common
    /// 加密
    public class EncryptHelper
        #region MD5加密
        /// GetMD5
        /// <param name="str"></param>
        /// <returns></returns>
        public static string EncryptMD5(string source)
            byte[] b = System.Text.Encoding.Default.GetBytes(source);
            b = new System.Security.Cryptography.MD5CryptoServiceProvider().ComputeHash(b);
            string ret = "";
            for (int i = 0; i < b.Length; i++)
                ret += b[i].ToString("x").PadLeft(2, '0');
            return ret;
        /// 用MD5加密,全大写
        /// <param name="source">待加密字符串</param>
        /// <returns>加密后字符串</returns>
        public static string EncryptMD5ToUpper(string source)
            return System.Web.Security.FormsAuthentication.HashPasswordForStoringInConfigFile(source, "md5").ToUpper();
        #endregion
        #region DES加密
        //默认密钥向量
        private static byte[] Keys = { 0xEF, 0xAB, 0x56, 0x78, 0x90, 0x34, 0xCD, 0x12 };
        /// DES加密字符串
        /// <param name="encryptString">待加密的字符串</param>
        /// <param name="encryptKey">加密密钥,要求为8位</param>
        /// <returns>加密成功返回加密后的字符串,失败返回源串</returns>
        public static string EncryptDES(string encryptString, string encryptKey)
            try
                byte[] rgbKey = Encoding.UTF8.GetBytes(encryptKey.Substring(0, 8));
                byte[] rgbIV = Keys;
                byte[] inputByteArray = Encoding.UTF8.GetBytes(encryptString);
                DESCryptoServiceProvider dCSP = new DESCryptoServiceProvider();
                MemoryStream mStream = new MemoryStream();
                CryptoStream cStream = new CryptoStream(mStream, dCSP.CreateEncryptor(rgbKey, rgbIV), CryptoStreamMode.Write);
                cStream.Write(inputByteArray, 0, inputByteArray.Length);
                cStream.FlushFinalBlock();
                return Convert.ToBase64String(mStream.ToArray());
            catch
                return encryptString;
        /// DES解密字符串
        /// <param name="decryptString">待解密的字符串</param>
        /// <param name="decryptKey">解密密钥,要求为8位,和加密密钥相同</param>
        /// <returns>解密成功返回解密后的字符串,失败返源串</returns>
        public static string DecryptDES(string decryptString, string decryptKey)
            try
                byte[] rgbKey = Encoding.UTF8.GetBytes(decryptKey.Substring(0, 8));
                byte[] inputByteArray = Convert.FromBase64String(decryptString);
                DESCryptoServiceProvider DCSP = new DESCryptoServiceProvider();
                CryptoStream cStream = new CryptoStream(mStream, DCSP.CreateDecryptor(rgbKey, rgbIV), CryptoStreamMode.Write);
                return Encoding.UTF8.GetString(mStream.ToArray());
            catch
                return decryptString;
        #endregion
        #region SHA1加密
        /// use sha1 to encrypt string
        public static string EncryptSHA1(string source)
            byte[] StrRes = Encoding.Default.GetBytes(source);
            HashAlgorithm iSHA = new SHA1CryptoServiceProvider();
            StrRes = iSHA.ComputeHash(StrRes);
            StringBuilder EnText = new StringBuilder();
            foreach (byte iByte in StrRes)
                EnText.AppendFormat("{0:x2}", iByte);
            return EnText.ToString();
        #endregion
        #region RSA加密
        /// RSA加密
        /// <param name="publickey"></param>
        /// <param name="content"></param>
        public static string EncryptRSA(string publickey, string content)
            RSACryptoServiceProvider rsa = new RSACryptoServiceProvider();
            byte[] cipherbytes;
            rsa.FromXmlString(publickey);
            cipherbytes = rsa.Encrypt(Encoding.UTF8.GetBytes(content), false);
            return Convert.ToBase64String(cipherbytes);
        /// RSA解密
        /// <param name="privatekey"></param>
        public static string DecryptRSA(string privatekey, string content)
            byte[] cipherbytes;
            rsa.FromXmlString(privatekey);
            cipherbytes = rsa.Decrypt(Convert.FromBase64String(content), false);
            return Encoding.UTF8.GetString(cipherbytes);
        #endregion
        #region AES加密
         * 跨程序使用AES加密,需要注意运算模式和填充模式;
         * 比如java
         * 需要设置
         * Mode = CipherMode.ECB; //C#默认运算模式为CBC,java默认为ECB,因此要将C#的加密方式改为ECB
         * Padding = PaddingMode.PKCS7; //设置为PKCS7,否则解密后字符串结尾会出现多余字符
         * 测试地址:http://www.seacha.com/tools/aes.html
        //默认密钥向量
        private static byte[] _Aeskey = { 0x12, 0x34, 0x56, 0x78, 0x90, 0xAB, 0xCD, 0xEF, 0x12, 0x34, 0x56, 0x78, 0x90, 0xAB, 0xCD, 0xEF };
        /// AES加密,返回Base64编码后的字符
        /// <param name="plainText">明文字符串</param>
        /// <param name="strKey">密钥</param>
        /// <returns>返回加密后的Base64编码字符串</returns>
        public static string EncryptAES(string plainText, string strKey)
            byte[] byteArray = Encoding.UTF8.GetBytes(plainText);
            RijndaelManaged rDel = new RijndaelManaged();
            rDel.Key = Encoding.UTF8.GetBytes(strKey);
            rDel.IV = _Aeskey;
            rDel.BlockSize = 128;
            rDel.Mode = CipherMode.ECB;//设置为ECB
            rDel.Padding = PaddingMode.PKCS7;//设置为PKCS7,否则解密后字符串结尾会出现多余字符
            ICryptoTransform cTransform = rDel.CreateEncryptor();
            var s = cTransform.TransformFinalBlock(byteArray, 0, byteArray.Length);
            var encrypt = Convert.ToBase64String(s);
            rDel.Clear();
            return encrypt;
        /// AES解密,返回解密后的字符串
        /// <param name="cipherText">Base64编码的密文</param>
        /// <returns>返回解密后的字符串</returns>
        public static string DecryptAES(string cipherText, string strKey)
            byte[] byteArray = Convert.FromBase64String(cipherText);
            rDel.IV = _Aeskey;
            rDel.Mode = CipherMode.ECB;//必须设置为ECB
            rDel.Padding = PaddingMode.PKCS7;//必须设置为PKCS7
            ICryptoTransform cTransform = rDel.CreateDecryptor();
            var decrypt = Encoding.UTF8.GetString(s);
            rDel.Clear();
            return decrypt;
        #endregion
        #region Base64编码
        public static string EncryptBase64(string source)
            byte[] bytes = Encoding.Default.GetBytes(source);
            return Convert.ToBase64String(bytes);
        public static string EncryptBase64(byte[] bytes)
        public static string DecryptBase64(string source)
            byte[] outputb = Convert.FromBase64String(source);
            return Encoding.Default.GetString(outputb);
        #endregion
        #region RSA-SHA1 数字签名
        /// 数字签名
        /// <param name="plaintext">原文</param>
        /// <param name="privateKey">私钥</param>
        /// <returns>Base64 签名</returns>
        public static string HashAndSignString(string plaintext, string privateKey)
            UTF8Encoding ByteConverter = new UTF8Encoding();
            byte[] dataToEncrypt = ByteConverter.GetBytes(plaintext);
            using (RSACryptoServiceProvider RSAalg = new RSACryptoServiceProvider())
                RSAalg.FromXmlString(privateKey);
                //使用SHA1进行摘要算法,生成签名
                byte[] encryptedData = RSAalg.SignData(dataToEncrypt, new SHA1CryptoServiceProvider());
                return Convert.ToBase64String(encryptedData);
        /// 验证签名
        /// <param name="SignedData">Base64 签名</param>
        /// <param name="publicKey">公钥</param>
        public static bool VerifySigned(string plaintext, string SignedData, string publicKey)
            try
                    RSAalg.FromXmlString(publicKey);
                    byte[] dataToVerifyBytes = ByteConverter.GetBytes(plaintext);
                    byte[] signedDataBytes = Convert.FromBase64String(SignedData);
                    return RSAalg.VerifyData(dataToVerifyBytes, new SHA1CryptoServiceProvider(), signedDataBytes);
            catch (Exception)
                return false;
        #endregion
文章内容转载自:cssteach.com
GMT+8, 2026-4-16 15:12
