查看: 3667|回复: 0
XtraGrid常见用法(一)
发表于 2019-3-25 15:10:36 | 显示全部楼层 |阅读模式
下面汇总了DevExpress XtraGrid控件的各种常见用法,在此分享给大家:
DevExpress Universal Suite下载
支持多种类型的数据集合作为数据源
XtraGrid与传统的DataGridView一样,支持多种类型作为其数据源。下面例子是将DataTable, List<T>和数组分别绑定到XtraGrid里面。
//定义数据源
List<Person> peopleList=new List<Person>
    { ID = 1, FirstName = "Magnus", LastName = "Hedlund", Sex = true, Birth = new DateTime(1999, 9, 9), Chinese = 60, English = 80, Math = 79 },
    { ID = 2, FirstName = "Terry", LastName = "Adams", Sex = false, Birth = new DateTime(1999, 9, 9), Chinese = 60, English = 80, Math = 79 },
    { ID = 3, FirstName = "Charlotte", LastName = "Weiss", Sex = false, Birth = new DateTime() },
    { ID = 4, FirstName = "Arlene", LastName = "Huff", Sex = true, Birth = new DateTime(1999, 9, 9), Chinese = 60, English = 80, Math = 79 },
    { ID = 5, FirstName = "FirstName1", LastName = "LastName1", Sex = true, Birth = new DateTime(1999, 9, 9), Chinese=60, English=80, Math=79 },
   { ID = 6, FirstName = "FirstName2", LastName = "LastName2", Sex = true, Birth = new DateTime(1999, 9, 19), Chinese = 60, English = 80, Math = 79 },
   { ID = 7, FirstName = "FirstName3", LastName = "LastName3", Sex = true, Birth = new DateTime(1999, 9, 29) },
   { ID = 8, FirstName = "FirstName4", LastName = "LastName4", Sex = true, Birth = new DateTime(1999, 2, 9), Chinese = 60, English = 80, Math = 79 },
   { ID = 9, FirstName = "FirstName5", LastName = "LastName5", Sex = true, Birth = new DateTime(1999, 4, 9) }
//将list<T>绑定到grid中
gridControl1.DataSource = peopleList;
People[] peopleArray=peopleList.ToArray();
//将数组绑定到grid中
gridControl1.DataSource = peopleArray;
DataTable peopleTable=new DataTable();
peopleTable.Columns.Add("FirstName");
peopleTable.Columns.Add("LastName");
peopleTable.Columns.Add("Sex");
peopleTable.Columns.Add("Birth");
peopleTable.Columns.Add("Chinese");
peopleTable.Columns.Add("English");
peopleTable.Columns.Add("Math");
peopleTable.Columns.Add("ID");
foreach (Person pi in people)
    DataRow row = peopleTable.Rows.Add();
    row["FirstName"] = pi.FirstName;
    row["LastName"] = pi.LastName;
    row["Sex"] = pi.Sex;
    row["Birth"] = pi.Birth;
    row["Chinese"] = pi.Chinese;
    row["English"] = pi.English;
    row["Math"] = pi.Math;
    row["ID"]=pi.ID;
//将DataTable绑定到grid中
gridControl1.DataSource = peopleTable;
统计运算的功能
XtraGrid提供的统计运算的功能,包括求和,求平均值,最大值,最小值,行数,自定义统计。
做法是打开属性编辑器,在Columns ——> Columns properties下的 SummaryItem的SummaryType选择。
或者通过代码设置,例如:
this.bandedGridColumn2.SummaryItem.SummaryType= DevExpress.Data.SummaryItemType.Average;
DevExpress.Data.SummaryItemType是一个枚举,它的值有 Sum,Average,Max,Min,Count,Custom和None。
排序
只要该列的ColumnsOptions的AllowSort属性不为False就可以根据那一列的数据进行排序。(AllowSort属性 在属性编辑器的Columns的Columns Options选项卡。)设置Column properties下的SortOrder值。
或者通过代码,例如:
this.bandedGridColumn2.OptionsColumn.AllowSort=  DevExpress.Utils.DefaultBoolean.Default| DevExpress.Utils.DefaultBoolean.True;
this.bandedGridColumn2.SortOrder= DevExpress.Data.ColumnSortOrder.Ascending
另外在程序运行时,单击某列的列头也可以对该列进行排序。
分组
GridView view = gridControl1.MainView as GridView;
[] sortInfo = {
        new GridColumnSortInfo(view.Columns["Chinese"], ColumnSortOrder.Ascending)
view.SortInfo.(sortInfo, 2);
GridColumnSortInfo 数组存放的是分组的列的信息,调用ClearAndAddRange清除结果并进行分组。
筛选
只要该列的Filter Options选项卡的AllowFilter属性不为False就可以进行筛选。
该属性通过代码设置是
this.bandedGridColumn2.OptionsFilter.AllowFilter = false;
运行程序后,鼠标指针移动到列标题,单击漏斗状图形经行筛选操作。
分页栏
XtraGrid提供分页栏。通过这个设置可以显示出来。
gridControl1.UseEmbeddedNavigator = true;
如果要根据滚动条滚动实现翻页功能的,那得依靠Scroll事件。它又没像DataGridView那样开放滚动条事件,不过里面有一个事件可以替代Scroll事件,那就是TopRowChanged,例子如下:
private void gridView1_TopRowChanged(object sender, EventArgs e)
            if (gridView1.IsRowVisible(gridView1.RowCount - 1) == RowVisibleState.Visible) //如果滚到了底端
                people.AddRange(new Person[] { Person1, Person2, Person3, Person4, Person5 });
如果硬要获取滚动条对象来设置,则可以用下面这段代码获取gridView的滚动条。
Type type = gridView1.GetType();
            FieldInfo fi = type.GetField("fViewInfo", BindingFlags.NonPublic | BindingFlags.Instance);
            GridViewInfo info = gridView1.GetViewInfo() as GridViewInfo;
            fi = type.GetField("scrollInfo", BindingFlags.NonPublic | BindingFlags.Instance);
            ScrollInfo scrollInfo = fi.GetValue(gridView1) as ScrollInfo;
父子表
当绑定的 数据源中的子项再存在集合时,XtraGrid会自动启用子表。例如上面的在Person类里多添加一个成员 List<Person> Friends{get;set;}表示那个人的朋友圈子,在任意一个实例中把Person实例添加进去,再启动程序时,就会发现父子表的效果实现了。
若要对子表的进行设置,可以给MainView添加MasterRowExpanded事件,例如:
private void gridView1_MasterRowExpanded(object sender, CustomMasterRowEventArgs e)
            //获取子表
            AdvBandedGridView gv = (AdvBandedGridView)gridView1.GetDetailView(e.RowHandle, e.RelationIndex);
            //第一个参数是行号,第二个参数是父子表关联索引
            if (gv != null)
                //对子表设置
Get/Set 单元格的值
通过调用GetRowCellValue获取单元格的值。
public override object GetRowCellValue(
   int rowHandle,
   GridColumn column
rowHandle是行的索引,column列的对象。
通过调用SetRowCellValue设置单元格的值
public void SetRowCellValue(
   int rowHandle,
   GridColumn column,
   object _value
rowHandle是行的索引,column列的对象。_value是单元格新的值。
以peopleList为例
int englishS=Convert.ToDouble(0,gridView1.Columns["English"])+60;
SetRowCellValue(0,gridView1.Columns["English"],englishS);
在XtraGrid有另一种方式,就是直接设置数据源的值。对于上面这个例子,直接找到grid里第一行数据对应的Person对象,设置它的English值。
出处:博客园武胜-阿伟
kevenme + 1 感谢分享
GMT+8, 2025-4-4 17:48
