查看: 3776|回复: 1
XtraGridControl动态添加右键菜单
发表于 2019-3-28 14:44:28 | 显示全部楼层 |阅读模式
DevExpress Universal Suite最新版下载
在使用 GridControl 的时候经常需要添加右键菜单。一般的做法是自己创建菜单项,然后注册GridView的Mouse-Click事件,然后Show出定义好的菜单。但是涉及到一些单击事件会收到编辑器编辑状态影响,所以Mouse-Click事件不好用。
幸好,GridView自带了一个默认的右键事件,专门用于弹出右键菜单用:PopupMenuShowing
为了调用方便,设计成一个静态方法,调用的时候只用传入需要注册的网格就好:
GridViewMenuHelper.CreateCopyCellItem(gdvw);
这里,为传入网格添加一个名为【复制XXX】(XXX为列头)的方法,可以将鼠标点中的Cell中的数据复制到剪贴板。
实现代码如下:
#region 添加复制Cell菜单
        public static void CreateCopyCellItem(GridView View)
            View.PopupMenuShowing += new PopupMenuShowingEventHandler(Create_CopyCellItem);
        static void Create_CopyCellItem(object sender, PopupMenuShowingEventArgs e)
            if (e.MenuType == DevExpress.XtraGrid.Views.Grid.GridMenuType.Row)
                if (e.HitInfo.InRowCell)
                    e.Menu.Items.Add(CreateCopyMenuItem((GridView)sender, e.HitInfo.RowHandle, e.HitInfo.Column));
        static DXMenuItem CreateCopyMenuItem(GridView view, int rowHandle, GridColumn column)
            DXMenuItem copyitem = new DXMenuItem("复制" + column.Caption,
                new EventHandler(OnCopyCellClick), null);
            copyitem.Tag = column;
            return copyitem;
        static void OnCopyCellClick(object sender, EventArgs e)
            GridColumn col = (GridColumn)((DXMenuItem)sender).Tag;
            string filed = col.FieldName;
            Clipboard.SetDataObject(col.View.GetRowCellDisplayText(col.View.FocusedRowHandle, col), true);
        #endregion
补充:
public class GridViewAddPopupMenuBase
       EventHandler OnClearCellClick;
       string MenuName;
       public static void CreateNewCellItem(GridView View, string cMenuName, EventHandler DoClearCellClick)
           GridViewAddPopupMenuBase gb = new GridViewAddPopupMenuBase();
           gb.OnClearCellClick = DoClearCellClick;
           gb.MenuName = cMenuName;
           View.PopupMenuShowing += new PopupMenuShowingEventHandler(gb.Create_NewCellItem);
       void Create_NewCellItem(object sender, PopupMenuShowingEventArgs e)
               if (((GridView)sender).OptionsBehavior.Editable == true)
                   if (e.HitInfo.InRowCell && e.HitInfo.Column.OptionsColumn.AllowEdit == true)
                       e.Menu.Items.Add(CreateNewMenuItem((GridView)sender, e.HitInfo.RowHandle, e.HitInfo.Column));
       DXMenuItem CreateNewMenuItem(GridView view, int rowHandle, GridColumn column)
           DXMenuItem copyitem = new DXMenuItem(MenuName.Replace("[Caption]", column.Caption.Replace("\r\n","")),
               new EventHandler(OnClearCellClick), null);
           return copyitem;
   public class GridViewCreateNewCellItem : GridViewAddPopupMenuBase
       #region 添加复制Cell菜单
       public static void CreateClearCellItem(GridView View)
           CreateNewCellItem(View, "清除[Caption]", DoClear);
       private static void DoClear(object sender, EventArgs e)
           col.View.SetRowCellValue(col.View.FocusedRowHandle, col, DBNull.Value);
       #endregion
使用:Load事件增加
GridViewCreateNewCellItem.CreateClearCellItem(gv_Wool);
GridViewCreateNewCellItem.CreateClearCellItem(gv_Ast);
GridViewCreateNewCellItem.CreateClearCellItem(gv_ZJ);
GridViewCreateNewCellItem.CreateClearCellItem(gv_Process2);
GridViewCreateNewCellItem.CreateClearCellItem(gv_SpecialProcess);
Demo下载:http://pan.baidu.com/s/1bnCijtP
Via GarsonZhang
134 小时
发表于 2019-4-11 21:16:56 | 显示全部楼层
连接失效了,能否重新发一下,谢谢楼主
GMT+8, 2025-4-4 17:48
