查看: 4256|回复: 4
[源码] SQLHelper类常用操作
514 小时
发表于 2020-3-15 18:38:10 | 显示全部楼层 |阅读模式
[ 本帖最后由 feiibao2020 于 2020-3-16 19:48 编辑 ]\n\nusing System;
using System.Linq;
using System.Text;
using System.Data;
using System.Data.SqlClient;
using System.Configuration;
namespace DAL
    ///  通用数据访问类
    class SQLHelper
        private static readonly string connString =
            ConfigurationManager.ConnectionStrings["connString"].ToString();
        /// 执行增、删、改(insert/update/delete)
        /// <param name="sql"></param>
        /// <returns></returns>
        public static int Update(string sql)
            SqlConnection conn = new SqlConnection(connString);
            SqlCommand cmd = new SqlCommand(sql, conn);
            try
                conn.Open();
                int result = cmd.ExecuteNonQuery();
                return result;
            catch (Exception ex)
                throw ex;
            finally
                conn.Close();
        /// 执行单一结果查询(select)
        public static object GetSingleResult(string sql)
            try
                conn.Open();
                object result = cmd.ExecuteScalar();
                return result;
                throw ex;
            finally
                conn.Close();
        /// 执行多结果查询(select)
        public static SqlDataReader GetReader(string sql)
            try
                conn.Open();
                SqlDataReader objReader =
                    cmd.ExecuteReader(CommandBehavior.CloseConnection);
                return objReader;
                conn.Close();
                throw ex;
        /// 执行返回数据集的查询
        public static DataSet GetDataSet(string sql)
            SqlDataAdapter da = new SqlDataAdapter(cmd); //创建数据适配器对象
            DataSet ds = new DataSet();//创建一个内存数据集
            try
                conn.Open();
                da.Fill(ds);  //使用数据适配器填充数据集
                return ds;  //返回数据集
                throw ex;
            finally
                conn.Close();
        public static DataSet GetDataSet(string sql,SqlParameter[] param)
            cmd.Parameters.AddRange(param);
            try
                conn.Open();
                da.Fill(ds);
                return ds;
                throw ex;
            finally
                conn.Close();
        /// 启用事务执行多条SQL语句
        /// <param name="sqlList">SQL语句列表</param>
        public static bool UpdateByTran(List<string> sqlList)
            SqlCommand cmd = new SqlCommand();
            cmd.Connection = conn;
            try
                conn.Open();
                cmd.Transaction = conn.BeginTransaction();   //开启事务
                foreach (string itemSql in sqlList)//循环提交SQL语句
                    cmd.CommandText = itemSql;
                cmd.Transaction.Commit();  //提交事务(同时自动清除事务)
                return true;
                if (cmd.Transaction != null)
                    cmd.Transaction.Rollback();//回滚事务(同时自动清除事务)
                throw new Exception("调用事务方法UpdateByTran(List<string> sqlList)时出现错误:" + ex.Message);
            finally
                    cmd.Transaction = null;
                conn.Close();
        /// 获取服务器的时间
        public static DateTime GetServerTime()
            return Convert.ToDateTime(GetSingleResult("select getdate()"));
发表于 2020-4-30 16:22:11 | 显示全部楼层
此帖仅作者可见
514 小时
 楼主| 发表于 2020-4-30 20:02:52 | 显示全部楼层
此帖仅作者可见
发表于 2020-4-30 20:13:11 | 显示全部楼层
此帖仅作者可见
514 小时
 楼主| 发表于 2020-4-30 21:52:17 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-4-20 22:55
