查看: 28871|回复: 64
Arction LightningChart .NET 8.5.1.4001 / JS 1.2.2
143 小时
发表于 2020-8-6 11:01:32 | 显示全部楼层 |阅读模式
国外搬运,可以下载
LightningChart is a complete programming kit for fast two-dimensional and 3D calculations in the field of measurement, engineering and visualization of research data for the .NET programming framework. With this sdk, programmers can use a variety of 2D and 3D controls to draw information chart and display their desired information in beautiful graphical formats. The frameworks of this collection are provided for both The Vienna Form and WPF and in both environments all the capabilities of this development kit can be used. The graphic charts of this complex use GPU hardware accelerator and are built over Direct3D, which increases the maximum efficiency of graphic drawing of this product.
If you use a lot of graphics and heavy chart in your program, we recommend that you use this product because its performis is much higher than standard WPF controls. The controls of this complex are created with the aim of high processing speed and programmers in their engineering programs can use a variety of computer-based oscillacs, signal analyzers, G.I.S. systems and other signal monitoring and instantaneous measurement systems. These controls are designed and implemented in a way that without the size and freezer of the graphical interface of the program, they can effectively process and display a large volume of data. 3D controls allow users to rotate the chart at the desired angle, change its size, and
https://downloadly.ir/software/programming/lightningchart/
各位大神,给个"赞扬"吧,这样动力更足!!!!
点击"评分" ,谢谢各位!!!
参与人数 4赞扬 +4 收起 理由
jshq2000 + 1 赞一个
loveboyzmj + 1 很给力
geriald + 1
gyqxue + 1 赞一个
发表于 2020-8-8 00:11:31 | 显示全部楼层
thanks  for you
16 小时
发表于 2020-8-13 20:04:51 | 显示全部楼层
thanks  for you
发表于 2020-8-13 23:02:31 | 显示全部楼层
感谢分享,试一试看看
发表于 2020-8-14 11:08:37 | 显示全部楼层
感谢大佬的资源,这是我想要的。谢谢!
发表于 2020-8-15 00:29:52 | 显示全部楼层
感谢分享,试一试看看
发表于 2020-8-19 23:41:23 | 显示全部楼层
看看能不能用
发表于 2020-8-20 14:28:53 | 显示全部楼层
thanks so much for the tool
27 小时
发表于 2020-8-21 11:27:25 | 显示全部楼层
感谢楼主分享
42 小时
发表于 2020-8-29 21:58:03 | 显示全部楼层
感谢分享哦
1637 小时
发表于 2020-9-13 12:13:31 | 显示全部楼层
感谢大佬的资源,
1637 小时
发表于 2020-9-13 12:14:32 | 显示全部楼层
感谢大佬的资源,
发表于 2020-9-18 04:38:41 | 显示全部楼层
thank you very mush
发表于 2020-9-21 15:25:28 | 显示全部楼层
thank you very mush
53 小时
发表于 2020-9-28 16:56:54 | 显示全部楼层
亲爱的楼主,支持asp.net吗?
82 小时
发表于 2020-9-29 20:56:57 | 显示全部楼层
thanks  for you
发表于 2020-9-30 10:04:55 | 显示全部楼层
真的谢谢~ 看看这个
169 小时
发表于 2020-10-2 00:11:42 | 显示全部楼层
Thanks for sharing
发表于 2020-10-18 20:40:58 | 显示全部楼层
是免费版吗有限制没
发表于 2020-10-26 10:30:19 | 显示全部楼层
thank you very much
362 小时
发表于 2020-10-28 16:22:38 | 显示全部楼层
thanks  for you
发表于 2020-10-30 09:49:40 | 显示全部楼层
XUEXIXUEXI~~~~
发表于 2020-11-7 16:40:05 | 显示全部楼层
这个难道比scichart还快吗???
发表于 2020-11-7 17:51:00 | 显示全部楼层
thanks  for you
87 小时
发表于 2020-11-9 14:01:04 | 显示全部楼层
it's so good, thank you very much
发表于 2020-11-19 17:12:31 | 显示全部楼层
好东西,谢谢分享
GMT+8, 2025-4-2 03:31
