查看: 6548|回复: 0
如何创建SpreadJS的Vue项目?这个方法3分钟搞定
发表于 2020-12-23 09:43:19 | 显示全部楼层 |阅读模式
概述
SpreadJS 纯前端表格控件 V11.2(SP2)版本已经全面支持了 Vue 拓展,下面我们看下如何配合 VUE CLI,只需 3 分钟快速构建一个 SpreadJS Vue 工程。
1. 安装vue-cli(耗时30 S)
通过命令:npm install -g \@vue/cli 安装(https://cli.vuejs.org/
2. 创建 vue-spreadjs 工程(耗时 1 Min)
请根据项目需求配置工程选项。
3. 通过npm install 或者在package.json中添加引用的方式安装spread.sheets(耗时20S)
"@grapecity/spread-excelio": "^11.2.3","@grapecity/spread-sheets": "^11.2.3","@grapecity/spread-sheets-print": "^11.2.3","@grapecity/spread-sheets-resources-zh": "^11.2.3","@grapecity/spread-sheets-vue": "^11.2.3",
4. 修改 router/index.js 为 spreadJS 页面添加 router(耗时 30 S)
routes: [{path: '/',name: 'HelloWorld',component: HelloWorld},{path: '/spreadjs',name: 'spreadJS',component: SpreadJS}]
5. 新建 SpreadJS Component(耗时 30 S)
请在 components 下添加 SpreadJS.vue 文件
template 内容:
<template><div><h1>Spread.Sheets</h1><div><input type='file' @change="processFile($event)"/><button @click="importExcel">导入</button><button @click="exportExcel">导出</button><button @click="printWorkbook">打印</button></div><div style="text-align: left"><gc-spread-sheetshostClass='spread-host'@workbookInitialized = 'workbookInitialized($event)'><gc-worksheet></gc-worksheet></gc-spread-sheets></div></div></template>Style内容:<style>.spread-host {width: 100%;height: 400px;border: 1px solid black;}</style>Script内容:<script>/* eslint-disable */import "@grapecity/spread-sheets/styles/gc.spread.sheets.excel2016colorful.css";import GC from "@grapecity/spread-sheets";import "@grapecity/spread-sheets-vue";import "@grapecity/spread-sheets-resources-zh";import ExcelIO from "@grapecity/spread-excelio";import FaverSaver from "file-saver";import "@grapecity/spread-sheets-print";GC.Spread.Common.CultureManager.culture("zh-cn"); GC.Spread.Sheets.LicenseKey = ExcelIO.LicenseKey = "your key"export default {methods: {processFile (event) {this.excelFile = event.target.files[0];},importExcel () {var excelIO = new ExcelIO.IO();console.log(excelIO);var self = this;excelIO.open(this.excelFile, function(json) {self.spread.fromJSON(json);console.log(json);});},exportExcel () {var excelIO = new ExcelIO.IO();var json = this.spread.toJSON();excelIO.save(json,function(blob) {FaverSaver.saveAs(blob, "export.xlsx");},function(e) {console.log(e);});},printWorkbook (){this.spread.print();},workbookInitialized(spread) {this.spread = spread;spread.refresh();}}}</script>
workbookInitialized 是 spread 初始化完成后的回调事件,我们可以在事件中得到初始化好的 workbook 对象。
部署授权需要同时给 Sheets 和 ExcelIO 同时添加,部署授权可以在全局 config 中配置。
6. 运行项目(耗时 10 S)
创建 npm install 依赖后,即可通过npm start启动项目
浏览器访问 http://localhost:8081/#/spreadjs 查看效果。
只需 3 分钟,一个 SpreadJS 的 Vue 项目就创建完成了,当然纯前端表格控件 SpreadJS 的强大不仅于此,去实际试用感受一下吧!
本文转载自葡萄城
GMT+8, 2025-4-2 11:41
