查看: 4640|回复: 1
WinForms中文帮助文档:表单控件 - XtraUserControl
发表于 2021-1-29 10:01:49 | 显示全部楼层 |阅读模式
XtraUserControl 类替代标准的System.Windows.Forms.UserControl组件,它提供了创建包含控件和组件的独立模块的功能,这些模块可以在整个应用程序中重复使用。
C#
//Create an XtraUserControl that represents a login form
public class LoginUserControl : XtraUserControl {
public LoginUserControl() {
LayoutControl lc = new LayoutControl();
lc.Dock = DockStyle.Fill;
TextEdit teLogin = new TextEdit();
TextEdit tePassword = new TextEdit();
CheckEdit ceKeep = new CheckEdit() { Text = "Keep me signed in" };
lc.AddItem(String.Empty, teLogin).TextVisible = false;
lc.AddItem(String.Empty, tePassword).TextVisible = false;
lc.AddItem(String.Empty, ceKeep);
this.Controls.Add(lc);
this.Dock = DockStyle.Fill;
//Show an XtraUserControl-based login form inside a dialog
private void simpleButton1_Click(object sender, EventArgs e) {
LoginUserControl myControl = new LoginUserControl();
DevExpress.XtraEditors.XtraDialog.Show(myControl, "Sign in", MessageBoxButtons.OKCancel);
VB.NET
'create an XtraUserControl that represents a login form
Public Class LoginUserControl
Inherits XtraUserControl
Public Sub New()
Dim lc As New LayoutControl()
Dim teLogin As New TextEdit()
Dim tePassword As New TextEdit()
Dim ceKeep As New CheckEdit() With {.Text = "Keep me signed in"}
lc.AddItem(String.Empty, teLogin).TextVisible = False
lc.AddItem(String.Empty, tePassword).TextVisible = False
Me.Controls.Add(lc)
Me.Dock = DockStyle.Fill
End Sub
End Class
'show an XtraUserControl-based login form inside a dialog
Private Sub simpleButton1_Click(ByVal sender As Object, ByVal e As EventArgs)
Dim myControl As New LoginUserControl()
End Sub
要在设计时添加XtraUserControls,请右键单击您的项目,然后选择 "Add DevExpress Item" 选项,这将调用Template Gallery,该库允许您添加空白XtraUserControls和DevExpress表单以及基于模板的表单。
与标准WinForms UserControl相比,XtraUserControl具有以下优点:
  • 最终用户可以在悬停时滚动XtraUserControl内容,而无需首先关注它;
  • 与布局和数据布局控件组件通信来传递正确的控件大小;
  • 允许您直接从承载此容器的表单(可视继承)中为XtraUserControl(或其子)内部的控件使用智能标记和Designer对话框;
  • 支持DevExpress皮肤,并确保整个应用程序的外观一致性。
658 小时
发表于 2021-1-29 15:06:04 | 显示全部楼层
这个方式不错,有没有非模态窗口的方式呢? 类似 Form.Show() ??
GMT+8, 2025-4-5 04:39
