查看: 6375|回复: 0
表单控件 - 动态更新Wait Form的标题或描述
发表于 2021-3-4 10:18:35 | 显示全部楼层 |阅读模式
点击获取DevExpress完整版下载
启动屏幕管理器在单独的线程中显示Wait Form,若要在显示Wait Form时动态更改标签,请使用SplashScreenManager.SetWaitFormCaption和SetWaitFormDescription方法。
注意:完成的示例项目位于https://github.com/DevExpress-Examples/how-to-dynamically-change-a-wait-forms-labels-e3575
Form1.cs
[CSS] 纯文本查看 复制代码
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using DevExpress.XtraSplashScreen;
using System.Threading;
namespace WaitForm_SetDescription {
public partial class Form1 : Form {
public Form1() {
InitializeComponent();
private void btnShowWaitForm_Click(object sender, EventArgs e) {
//Open Wait Form
SplashScreenManager.ShowForm(this, typeof(WaitForm1), true, true, false);
//The Wait Form is opened in a separate thread. To change its Description, use the SetWaitFormDescription method.
for (int i = 1; i <= 100; i++) {
SplashScreenManager.Default.SetWaitFormDescription(i.ToString() + "%");
Thread.Sleep(25);
//Close Wait Form
SplashScreenManager.CloseForm(false);
Form1.vb
Imports Microsoft.VisualBasic
Imports System
Imports System.Collections.Generic
Imports System.ComponentModel
Imports System.Data
Imports System.Drawing
Imports System.Linq
Imports System.Text
Imports System.Windows.Forms
Imports DevExpress.XtraSplashScreen
Imports System.Threading
Namespace WaitForm_SetDescription
Partial Public Class Form1
Inherits Form
Public Sub New()
End Sub
Private Sub btnShowWaitForm_Click(ByVal sender As Object, ByVal e As EventArgs) Handles btnShowWaitForm.Click
'Open Wait Form
SplashScreenManager.ShowForm(Me, GetType(WaitForm1), True, True, False)
'The Wait Form is opened in a separate thread. To change its Description, use the SetWaitFormDescription method.
For i As Integer = 1 To 100
SplashScreenManager.Default.SetWaitFormDescription(i.ToString() & "%")
Thread.Sleep(25)
Next i
'Close Wait Form
SplashScreenManager.CloseForm(False)
End Sub
End Class
End Namespace
上DevExpress中文网,获取第一手最新产品资讯!
GMT+8, 2025-4-5 04:39
