查看: 6810|回复: 0
应用程序数据管理新妙招!在维度标签中设置日期格式
发表于 2021-3-22 09:39:51 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R1 2021 SP1试用版下载
通过PivotGrid,您可以控制尺寸标签呈现的内容格式。
通过在行或标题模板中实现自定义模板,可以实现此操作。
下面的示例演示如何在PivotGrid中格式化维度标签的日期值。
[HTML] 纯文本查看 复制代码
<script src="https://demos.telerik.com/kendo-ui/content/shared/js/products.js"></script>
<div id="example">
<div id="pivotgrid"></div>
<div class="responsive-message"></div>
<script id="rowTemplate" type="text/x-kendo-template">
# if (member.name.indexOf("LastSupply") === 0 && member.name !== "LastSupply") { #
#: kendo.toString(kendo.parseDate(member.caption), "d") #
# } else { #
#: member.caption #
</script>
<script>
var d = new Date();
products.forEach(function(p) {
p.LastSupply = new Date(d);
d.setDate(d.getDate() + 1);
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
columnWidth: 120,
height: 570,
rowHeaderTemplate: $("#rowTemplate").html(),
dataSource: {
data: products,
schema: {
model: {
fields: {
ProductName: { type: "string" },
UnitPrice: { type: "number" },
UnitsInStock: { type: "number" },
Discontinued: { type: "boolean" },
LastSupply: { type: "date" },
CategoryName: { field: "Category.CategoryName" }
cube: {
dimensions: {
ProductName: { caption: "All Products" },
CategoryName: { caption: "All Categories" },
Discontinued: { caption: "Discontinued" }
measures: {
"Sum": { field: "UnitPrice", format: "{0:c}", aggregate: "sum" },
"Average": { field: "UnitPrice", format: "{0:c}", aggregate: "average" }
columns: [{ name: "CategoryName", expand: true }, { name: "ProductName" } ],
rows: [{ name: "Discontinued", expand: true }, { name: "LastSupply", expand: false }],
measures: ["Sum"]
}).data("kendoPivotGrid");
</script>
</div>
GMT+8, 2025-4-21 08:08
