查看: 5991|回复: 0
Kendo UI for jQuery数据管理使用教程:将行标题字幕显示为锚点
发表于 2021-4-6 10:14:45 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R1 2021 SP2试用版下载
PivotGrid允许您将标题呈现为锚点。
要将列标题和单元格标题字段呈现为锚点,请分别使用columnHeaderTemplate或dataCellTemplate选项。
要将行标题字段呈现为锚点,请使用rowHeaderTemplate选项,下面的示例演示如何实现此操作。
[HTML] 纯文本查看 复制代码
<script src="https://demos.telerik.com/kendo-ui/content/shared/js/products.js"></script>
<div id="example">
<div id="pivotgrid"></div>
<script id="headerTemplate" type="text/x-kendo-tmpl">
# if (!member.children.length && member.parentName === "ProductName") { #
<a href="https://www.telerik.com">#: member.caption #</a>
# } else { #
#: member.caption #
</script>
<script>
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
rowHeaderTemplate: $("#headerTemplate").html(),
columnWidth: 120,
height: 570,
dataSource: {
data: products,
schema: {
model: {
fields: {
ProductName: { type: "string" },
UnitPrice: { type: "number" },
UnitsInStock: { type: "number" },
Discontinued: { type: "boolean" },
CategoryName: { field: "Category.CategoryName" }
cube: {
dimensions: {
ProductName: { caption: "All Products" },
CategoryName: { caption: "All Categories" },
Discontinued: { caption: "Discontinued" }
measures: {
"Sum": { field: "UnitPrice", format: "{0:c}", aggregate: "sum" },
"Average": { field: "UnitPrice", format: "{0:c}", aggregate: "average" }
rows: [{ name: "CategoryName", expand: true }, { name: "ProductName" } ],
columns: [{ name: "Discontinued", expand: true }],
measures: ["Sum"]
}).data("kendoPivotGrid");
$("#configurator").kendoPivotConfigurator({
dataSource: pivotgrid.dataSource,
height: 570
</script>
</div>
GMT+8, 2025-2-23 13:38
