- 0
- 0 小时
- 1
- 2015-8-18
- 9
- 2015-8-18
- 9
- 85
- 0 小时
- 2015-8-18
public class HttpHelper
#region 预定义方变量
//默认的编码
private Encoding encoding = Encoding.Default;
//Post数据编码
private Encoding postencoding = Encoding.Default;
//HttpWebRequest对象用来发起请求
private HttpWebRequest request = null;
//获取影响流的数据对象
private HttpWebResponse response = null;
#endregion
#region Public
/// 根据相传入的数据,得到相应页面数据
/// <param name="item">参数类对象</param>
/// <returns>返回HttpResult类型</returns>
public HttpResult GetHtml(HttpItem item)
//返回参数
HttpResult result = new HttpResult();
try
//准备参数
SetRequest(item);
catch (Exception ex)
//配置参数时出错
return new HttpResult() { Cookie = string.Empty, Header = null, Html = ex.Message, StatusDescription = "配置参数时出错:" + ex.Message };
try
//请求数据
using (response = (HttpWebResponse)request.GetResponse())
GetData(item, result);
catch (WebException ex)
using (response = (HttpWebResponse)ex.Response)
result.Html = ex.Message;
if (item.IsToLower) result.Html = result.Html.ToLower();
return result;
#endregion
#region GetData
/// 获取数据的并解析的方法
/// <param name="item"></param>
/// <param name="result"></param>
private void GetData(HttpItem item, HttpResult result)
#region base
//获取StatusCode
result.StatusCode = response.StatusCode;
//获取StatusDescription
result.StatusDescription = response.StatusDescription;
//获取Headers
result.Header = response.Headers;
//获取CookieCollection
if (response.Cookies != null) result.CookieCollection = response.Cookies;
//获取set-cookie
if (response.Headers["set-cookie"] != null) result.Cookie = response.Headers["set-cookie"];
#endregion
#region byte
//处理网页Byte
byte[] ResponseByte = GetByte();
#endregion
#region Html
if (ResponseByte != null & ResponseByte.Length > 0)
//设置编码
SetEncoding(item, result, ResponseByte);
//得到返回的HTML
result.Html = encoding.GetString(ResponseByte);
else
//没有返回任何Html代码
result.Html = string.Empty;
#endregion
/// 设置编码
/// <param name="item">HttpItem</param>
/// <param name="result">HttpResult</param>
/// <param name="ResponseByte">byte[]</param>
private void SetEncoding(HttpItem item, HttpResult result, byte[] ResponseByte)
//是否返回Byte类型数据
if (item.ResultType == ResultType.Byte) result.ResultByte = ResponseByte;
//从这里开始我们要无视编码了
if (encoding == null)
Match meta = Regex.Match(Encoding.Default.GetString(ResponseByte), "<meta[^<]*charset=([^<]*)[\"']", RegexOptions.IgnoreCase);
string c = string.Empty;
if (meta != null && meta.Groups.Count > 0)
c = meta.Groups[1].Value.ToLower().Trim();
if (c.Length > 2)
try
encoding = Encoding.GetEncoding(c.Replace("\"", string.Empty).Replace("'", "").Replace(";", "").Replace("iso-8859-1", "gbk").Trim());
catch
if (string.IsNullOrEmpty(response.CharacterSet))
encoding = Encoding.UTF8;
else
encoding = Encoding.GetEncoding(response.CharacterSet);
else
else
/// 提取网页Byte
/// <returns></returns>
private byte[] GetByte()
byte[] ResponseByte = null;
MemoryStream _stream = new MemoryStream();
//GZIIP处理
if (response.ContentEncoding != null && response.ContentEncoding.Equals("gzip", StringComparison.InvariantCultureIgnoreCase))
//开始读取流并设置编码方式
_stream = GetMemoryStream(new GZipStream(response.GetResponseStream(), CompressionMode.Decompress));
else
//开始读取流并设置编码方式
_stream = GetMemoryStream(response.GetResponseStream());
//获取Byte
ResponseByte = _stream.ToArray();
_stream.Close();
return ResponseByte;
/// 4.0以下.net版本取数据使用
/// <param name="streamResponse">流</param>
private MemoryStream GetMemoryStream(Stream streamResponse)
int Length = 256;
Byte[] buffer = new Byte[Length];
int bytesRead = streamResponse.Read(buffer, 0, Length);
while (bytesRead > 0)
_stream.Write(buffer, 0, bytesRead);
return _stream;
#endregion
#region SetRequest
/// 为请求准备参数
///<param name="item">参数列表</param>
private void SetRequest(HttpItem item)
// 验证证书
SetCer(item);
//设置Header参数
if (item.Header != null && item.Header.Count > 0) foreach (string key in item.Header.AllKeys)
request.Headers.Add(key, item.Header[key]);
// 设置代理
SetProxy(item);
if (item.ProtocolVersion != null) request.ProtocolVersion = item.ProtocolVersion;
request.ServicePoint.Expect100Continue = item.Expect100Continue;
//请求方式Get或者Post
request.Method = item.Method;
request.Timeout = item.Timeout;
request.KeepAlive = item.KeepAlive;
request.ReadWriteTimeout = item.ReadWriteTimeout;
if (item.IfModifiedSince != null) request.IfModifiedSince = Convert.ToDateTime(item.IfModifiedSince);
//Accept
request.Accept = item.Accept;
//ContentType返回类型
request.ContentType = item.ContentType;
//UserAgent客户端的访问类型,包括浏览器版本和操作系统信息
request.UserAgent = item.UserAgent;
// 编码
encoding = item.Encoding;
//设置安全凭证
request.Credentials = item.ICredentials;
//设置Cookie
SetCookie(item);
//来源地址
request.Referer = item.Referer;
//是否执行跳转功能
request.AllowAutoRedirect = item.Allowautoredirect;
if (item.MaximumAutomaticRedirections > 0)
request.MaximumAutomaticRedirections = item.MaximumAutomaticRedirections;
//设置Post数据
SetPostData(item);
//设置最大连接
if (item.Connectionlimit > 0) request.ServicePoint.ConnectionLimit = item.Connectionlimit;
/// 设置证书
private void SetCer(HttpItem item)
if (!string.IsNullOrEmpty(item.CerPath))
//这一句一定要写在创建连接的前面。使用回调的方法进行证书验证。
ServicePointManager.ServerCertificateValidationCallback = new System.Net.Security.RemoteCertificateValidationCallback(CheckValidationResult);
//初始化对像,并设置请求的URL地址
request = (HttpWebRequest)WebRequest.Create(item.URL);
SetCerList(item);
//将证书添加到请求里
request.ClientCertificates.Add(new X509Certificate(item.CerPath));
else
//初始化对像,并设置请求的URL地址
SetCerList(item);
/// 设置多个证书
private void SetCerList(HttpItem item)
if (item.ClentCertificates != null && item.ClentCertificates.Count > 0)
foreach (X509Certificate c in item.ClentCertificates)
request.ClientCertificates.Add(c);
/// 设置Cookie
/// <param name="item">Http参数</param>
private void SetCookie(HttpItem item)
if (!string.IsNullOrEmpty(item.Cookie)) request.Headers[HttpRequestHeader.Cookie] = item.Cookie;
//设置CookieCollection
if (item.ResultCookieType == ResultCookieType.CookieCollection)
request.CookieContainer = new CookieContainer();
if (item.CookieCollection != null && item.CookieCollection.Count > 0)
request.CookieContainer.Add(item.CookieCollection);
/// 设置Post数据
private void SetPostData(HttpItem item)
//验证在得到结果时是否有传入数据
if (request.Method.Trim().ToLower().Contains("post"))
if (item.PostEncoding != null)
postencoding = item.PostEncoding;
byte[] buffer = null;
//写入Byte类型
if (item.PostDataType == PostDataType.Byte && item.PostdataByte != null && item.PostdataByte.Length > 0)
//验证在得到结果时是否有传入数据
buffer = item.PostdataByte;
}//写入文件
else if (item.PostDataType == PostDataType.FilePath && !string.IsNullOrEmpty(item.Postdata))
StreamReader r = new StreamReader(item.Postdata, postencoding);
buffer = postencoding.GetBytes(r.ReadToEnd());
r.Close();
} //写入字符串
else if (!string.IsNullOrEmpty(item.Postdata))
buffer = postencoding.GetBytes(item.Postdata);
if (buffer != null)
request.ContentLength = buffer.Length;
request.GetRequestStream().Write(buffer, 0, buffer.Length);
/// 设置代理
/// <param name="item">参数对象</param>
private void SetProxy(HttpItem item)
bool isIeProxy = false;
if (!string.IsNullOrEmpty(item.ProxyIp))
isIeProxy = item.ProxyIp.ToLower().Contains("ieproxy");
if (!string.IsNullOrEmpty(item.ProxyIp) && !isIeProxy)
//设置代理服务器
if (item.ProxyIp.Contains(":"))
string[] plist = item.ProxyIp.Split(':');
WebProxy myProxy = new WebProxy(plist[0].Trim(), Convert.ToInt32(plist[1].Trim()));
//建议连接
myProxy.Credentials = new NetworkCredential(item.ProxyUserName, item.ProxyPwd);
//给当前请求对象
request.Proxy = myProxy;
else
WebProxy myProxy = new WebProxy(item.ProxyIp, false);
//建议连接
//给当前请求对象
else if (isIeProxy)
//设置为IE代理
else
request.Proxy = item.WebProxy;
#endregion
#region private main
/// 回调验证证书问题
/// <param name="sender">流对象</param>
/// <param name="certificate">证书</param>
/// <param name="chain">X509Chain</param>
/// <param name="errors">SslPolicyErrors</param>
/// <returns>bool</returns>
private bool CheckValidationResult(object sender, X509Certificate certificate, X509Chain chain, SslPolicyErrors errors) { return true; }
#endregion
/// Http请求参考类
public class HttpItem
string _URL = string.Empty;
/// 请求URL必须填写
public string URL
get { return _URL; }
set { _URL = value; }
string _Method = "GET";
/// 请求方式默认为GET方式,当为POST方式时必须设置Postdata的值
public string Method
get { return _Method; }
set { _Method = value; }
int _Timeout = 100000;
/// 默认请求超时时间
public int Timeout
get { return _Timeout; }
set { _Timeout = value; }
int _ReadWriteTimeout = 30000;
/// 默认写入Post数据超时间
public int ReadWriteTimeout
get { return _ReadWriteTimeout; }
set { _ReadWriteTimeout = value; }
Boolean _KeepAlive = true;
/// 获取或设置一个值,该值指示是否与 Internet 资源建立持久性连接默认为true。
public Boolean KeepAlive
get { return _KeepAlive; }
set { _KeepAlive = value; }
string _Accept = "text/html, application/xhtml+xml, */*";
/// 请求标头值 默认为text/html, application/xhtml+xml, */*
public string Accept
get { return _Accept; }
set { _Accept = value; }
string _ContentType = "text/html";
/// 请求返回类型默认 text/html
public string ContentType
get { return _ContentType; }
set { _ContentType = value; }
string _UserAgent = "Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0)";
/// 客户端访问信息默认Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0)
public string UserAgent
get { return _UserAgent; }
set { _UserAgent = value; }
Encoding _Encoding = null;
/// 返回数据编码默认为NUll,可以自动识别,一般为utf-8,gbk,gb2312
public Encoding Encoding
get { return _Encoding; }
set { _Encoding = value; }
private PostDataType _PostDataType = PostDataType.String;
/// Post的数据类型
public PostDataType PostDataType
get { return _PostDataType; }
set { _PostDataType = value; }
string _Postdata = string.Empty;
/// Post请求时要发送的字符串Post数据
public string Postdata
get { return _Postdata; }
set { _Postdata = value; }
private byte[] _PostdataByte = null;
/// Post请求时要发送的Byte类型的Post数据
public byte[] PostdataByte
get { return _PostdataByte; }
set { _PostdataByte = value; }
private WebProxy _WebProxy;
/// 设置代理对象,不想使用IE默认配置就设置为Null,而且不要设置ProxyIp
public WebProxy WebProxy
get { return _WebProxy; }
set { _WebProxy = value; }
CookieCollection cookiecollection = null;
/// Cookie对象集合
public CookieCollection CookieCollection
get { return cookiecollection; }
set { cookiecollection = value; }
string _Cookie = string.Empty;
/// 请求时的Cookie
public string Cookie
get { return _Cookie; }
set { _Cookie = value; }
string _Referer = string.Empty;
/// 来源地址,上次访问地址
public string Referer
get { return _Referer; }
set { _Referer = value; }
string _CerPath = string.Empty;
/// 证书绝对路径
public string CerPath
get { return _CerPath; }
set { _CerPath = value; }
private Boolean isToLower = false;
/// 是否设置为全文小写,默认为不转化
public Boolean IsToLower
get { return isToLower; }
set { isToLower = value; }
private Boolean allowautoredirect = false;
/// 支持跳转页面,查询结果将是跳转后的页面,默认是不跳转
public Boolean Allowautoredirect
get { return allowautoredirect; }
set { allowautoredirect = value; }
private int connectionlimit = 1024;
/// 最大连接数
public int Connectionlimit
get { return connectionlimit; }
set { connectionlimit = value; }
private string proxyusername = string.Empty;
/// 代理Proxy 服务器用户名
public string ProxyUserName
get { return proxyusername; }
set { proxyusername = value; }
private string proxypwd = string.Empty;
/// 代理 服务器密码
public string ProxyPwd
get { return proxypwd; }
set { proxypwd = value; }
private string proxyip = string.Empty;
/// 代理 服务IP ,如果要使用IE代理就设置为ieproxy
public string ProxyIp
get { return proxyip; }
set { proxyip = value; }
private ResultType resulttype = ResultType.String;
/// 设置返回类型String和Byte
public ResultType ResultType
get { return resulttype; }
set { resulttype = value; }
private WebHeaderCollection header = new WebHeaderCollection();
/// header对象
public WebHeaderCollection Header
get { return header; }
set { header = value; }
private Version _ProtocolVersion;
// 获取或设置用于请求的 HTTP 版本。返回结果:用于请求的 HTTP 版本。默认为 System.Net.HttpVersion.Version11。
public Version ProtocolVersion
get { return _ProtocolVersion; }
set { _ProtocolVersion = value; }
private Boolean _expect100continue = true;
/// 获取或设置一个 System.Boolean 值,该值确定是否使用 100-Continue 行为。如果 POST 请求需要 100-Continue 响应,则为 true;否则为 false。默认值为 true。
public Boolean Expect100Continue
get { return _expect100continue; }
set { _expect100continue = value; }
private X509CertificateCollection _ClentCertificates;
/// 设置509证书集合
public X509CertificateCollection ClentCertificates
get { return _ClentCertificates; }
set { _ClentCertificates = value; }
private Encoding _PostEncoding;
/// 设置或获取Post参数编码,默认的为Default编码
public Encoding PostEncoding
get { return _PostEncoding; }
set { _PostEncoding = value; }
private ResultCookieType _ResultCookieType = ResultCookieType.String;
/// Cookie返回类型,默认的是只返回字符串类型
public ResultCookieType ResultCookieType
get { return _ResultCookieType; }
set { _ResultCookieType = value; }
private ICredentials _ICredentials = CredentialCache.DefaultCredentials;
/// 获取或设置请求的身份验证信息。
public ICredentials ICredentials
get { return _ICredentials; }
set { _ICredentials = value; }
/// 设置请求将跟随的重定向的最大数目
public int MaximumAutomaticRedirections { get; set; }
private DateTime? _IfModifiedSince = null;
/// 获取和设置IfModifiedSince,默认为当前日期和时间
public DateTime? IfModifiedSince
get { return _IfModifiedSince; }
set { _IfModifiedSince = value; }
/// Http返回参数类
public class HttpResult
private string _Cookie;
/// Http请求返回的Cookie
private CookieCollection _CookieCollection;
/// Cookie对象集合
get { return _CookieCollection; }
set { _CookieCollection = value; }
private string _Html;
/// 返回的String类型数据 只有ResultType.String时才返回数据,其它情况为空
public string Html
get { return _Html; }
set { _Html = value; }
private byte[] _ResultByte;
/// 返回的Byte数组 只有ResultType.Byte时才返回数据,其它情况为空
public byte[] ResultByte
get { return _ResultByte; }
set { _ResultByte = value; }
private WebHeaderCollection _Header;
/// header对象
get { return _Header; }
set { _Header = value; }
private string _StatusDescription;
/// 返回状态说明
public string StatusDescription
get { return _StatusDescription; }
set { _StatusDescription = value; }
private HttpStatusCode _StatusCode;
/// 返回状态码,默认为OK
public HttpStatusCode StatusCode
get { return _StatusCode; }
set { _StatusCode = value; }
/// 返回类型
public enum ResultType
/// 表示只返回字符串 只有Html有数据
String,
/// 表示返回字符串和字节流 ResultByte和Html都有数据返回
Byte
/// Post的数据格式默认为string
public enum PostDataType
/// 字符串类型,这时编码Encoding可不设置
String,
/// Byte类型,需要设置PostdataByte参数的值编码Encoding可设置为空
Byte,
/// 传文件,Postdata必须设置为文件的绝对路径,必须设置Encoding的值
FilePath
/// Cookie返回类型
public enum ResultCookieType
/// 只返回字符串类型的Cookie
String,
/// CookieCollection格式的Cookie集合同时也返回String类型的cookie
CookieCollection
