查看: 5481|回复: 0
Kendo UI for jQuery数据管理使用教程:PivotGrid - 显示工具提示
发表于 2021-4-15 09:29:55 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R1 2021 SP2试用版下载
以下示例演示了当用户将鼠标悬停在Kendo UI PivotGrid小部件中的数据单元格元素时如何显示工具提示。
[HTML] 纯文本查看 复制代码
<script src="https://demos.telerik.com/kendo-ui/content/shared/js/products.js"></script>
<div id="example">
<div id="pivotgrid"></div>
<script id="template" type="text/x-kendo-template">
<div>
<div>Rows: #:rowText#</div>
<div>Columns: #:columnText#</div>
<div>Value: #:value ? value : "N/A" #</div>
</div>
</script>
<script>
$("#pivotgrid").kendoPivotGrid({
columnWidth: 120,
height: 570,
dataSource: {
data: products,
schema: {
model: {
fields: {
ProductName: { type: "string" },
UnitPrice: { type: "number" },
UnitsInStock: { type: "number" },
Discontinued: { type: "boolean" },
CategoryName: { field: "Category.CategoryName" }
cube: {
dimensions: {
ProductName: { caption: "All Products" },
CategoryName: { caption: "All Categories" },
Discontinued: { caption: "All Discontinued" }
measures: {
"Sum": { field: "UnitPrice", format: "{0:c}", aggregate: "sum" }
rows: [{ name: "CategoryName", expand: true }, { name: "ProductName" } ],
columns: [{ name: "Discontinued", expand: true }],
measures: ["Sum"]
$(".k-grid-content").kendoTooltip({
filter: "td",
content: toolTip,
width: 400,
height: 100,
position: "top"
$(".k-grid-content").click(toolTip);
function toolTip(e) {
var target = $(e.target);
var grid = $("#pivotgrid").getKendoPivotGrid();
var cellInfo = grid.cellInfoByElement(target);
return kendo.template($("#template").html())({
rowText: generateName(cellInfo.rowTuple),
columnText: generateName(cellInfo.columnTuple),
value: cellInfo.dataItem.fmtValue
function generateName(tuple) {
var text = "";
var members = tuple.members;
for (var idx = 0, length = members.length; idx < length; idx++) {
text += members[idx].name;
if (members[idx + 1]) {
text += "->";
return text;
</script>
</div>
GMT+8, 2025-4-21 08:13
