查看: 4535|回复: 3
DevExpress如何实现自定义求和
发表于 2015-9-24 10:49:50 | 显示全部楼层 |阅读模式
概述:DevExpress实现自定义求和的效果图及事例代码
自定义求和的效果图如下:
代码如下:
C#
[size=1em]
[size=1em]1
[size=1em]2
[size=1em]3
[size=1em]4
[size=1em]5
[size=1em]6
[size=1em]7
[size=1em]8
[size=1em]9
[size=1em]10
[size=1em]11
[size=1em]12
[size=1em]13
[size=1em]14
[size=1em]15
[size=1em]16
[size=1em]17
[size=1em]18
[size=1em]19
[size=1em]20
[size=1em]21
[size=1em]22
[size=1em]23
[size=1em]24
[size=1em]25
[size=1em]26
[size=1em]27
[size=1em]28
[size=1em]29
[size=1em]30
[size=1em][size=1em]using DevExpress.XtraPivotGrid;
[size=1em]fieldExtendedPrice.Caption = "Percentage of Orders over $500";
[size=1em]// Enable a custom summary calculation for the Extended Price field.
[size=1em]fieldExtendedPrice.SummaryType = DevExpress.Data.PivotGrid.PivotSummaryType.Custom;
[size=1em]// Specify the settings used to format values.
[size=1em]fieldExtendedPrice.CellFormat.FormatType = DevExpress.Utils.FormatType.Numeric;
[size=1em]fieldExtendedPrice.CellFormat.FormatString = "p";
[size=1em]int minSum = 500;
[size=1em]private void pivotGridControl1_CustomSummary(object sender,
[size=1em]  PivotGridCustomSummaryEventArgs e) {
[size=1em]   if(e.DataField != fieldExtendedPrice) return;
[size=1em]   // A variable which counts the number of orders whose sum exceeds $500.
[size=1em]   int order500Count = 0;
[size=1em]   // Get the record set corresponding to the current cell.
[size=1em]   PivotDrillDownDataSource ds = e.CreateDrillDownDataSource();
[size=1em]   // Iterate through the records and count the orders.
[size=1em]   for(int i = 0; i < ds.RowCount; i++) {
[size=1em]      PivotDrillDownDataRow row = ds;
[size=1em]      // Get the order's total sum.
[size=1em]      decimal orderSum = (decimal)row[fieldExtendedPrice];
[size=1em]      if(orderSum >= minSum) order500Count ++;
[size=1em]   }
[size=1em]   // Calculate the percentage.
[size=1em]   if(ds.RowCount > 0) {
[size=1em]      e.CustomValue = (decimal)order500Count/ds.RowCount;
[size=1em]   }
[size=1em]}
VB
[size=1em]
[size=1em]1
[size=1em]2
[size=1em]3
[size=1em]4
[size=1em]5
[size=1em]6
[size=1em]7
[size=1em]8
[size=1em]9
[size=1em]10
[size=1em]11
[size=1em]12
[size=1em]13
[size=1em]14
[size=1em]15
[size=1em]16
[size=1em]17
[size=1em]18
[size=1em]19
[size=1em]20
[size=1em]21
[size=1em]22
[size=1em]23
[size=1em]24
[size=1em]25
[size=1em]26
[size=1em]27
[size=1em]28
[size=1em]29
[size=1em]30
[size=1em]31
[size=1em][size=1em]Imports DevExpress.XtraPivotGrid
[size=1em]' Enable a custom summary calculation for the Extended Price field.
[size=1em]' Specify the settings used to format values.
[size=1em]Dim minSum As Integer = 500
[size=1em]Private Sub PivotGridControl1_CustomSummary(ByVal sender As Object, _
[size=1em]  ByVal e As PivotGridCustomSummaryEventArgs) Handles PivotGridControl1.CustomSummary
[size=1em]   If Not e.DataField Is fieldExtendedPrice Then Return
[size=1em]   ' A variable which counts the number of orders whose sum exceeds $500.
[size=1em]   Dim order500Count As Integer = 0
[size=1em]   ' Get the record set corresponding to the current cell.
[size=1em]   Dim ds As PivotDrillDownDataSource = e.CreateDrillDownDataSource()
[size=1em]   ' Iterate through the records and count the orders.
[size=1em]   Dim i As Integer
[size=1em]   For i = 0 To ds.RowCount - 1
[size=1em]      Dim row As PivotDrillDownDataRow = ds(i)
[size=1em]      ' Get the order's total sum.
[size=1em]      Dim orderSum As Decimal = row(fieldExtendedPrice)
[size=1em]      If orderSum >= minSum Then order500Count = order500Count + 1
[size=1em]   Next
[size=1em]   ' Calculate the percentage.
[size=1em]   If ds.RowCount > 0 Then
[size=1em]      e.CustomValue = order500Count / ds.RowCount
[size=1em]   End If
[size=1em]End Sub
更多资讯
194 小时
发表于 2015-9-24 22:51:13 | 显示全部楼层
晕,这可怎么看啦
 楼主| 发表于 2015-9-25 09:39:17 | 显示全部楼层
bingw001 发表于 2015-9-24 22:51
晕,这可怎么看啦
呀,居然看不见了
24
25
26
29
30
int minSum = 500;
VB
24
25
26
29
30
31
   Dim i As Integer
   Next
   End If
End Sub
194 小时
发表于 2015-9-25 09:51:15 | 显示全部楼层
哇,谢谢楼主给修复了
GMT+8, 2025-4-19 18:00
