查看: 6301|回复: 1
Kendo UI for jQuery数据管理使用教程:PivotGrid - 修改导出的Exce...
发表于 2021-4-21 09:32:15 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R1 2021 SP2试用版下载
您可以通过修改生成的Workbook对象,将不同的样式和值更改应用于导出到Excel的Kendo UI PivtoGrid中。
下面的示例演示如何实现此操作。
[HTML] 纯文本查看 复制代码
<div id="example">
<button id="export">Export</button>
<div id="pivotgrid"></div>
<script>
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
excel: {
fileName: "Kendo UI PivotGrid Export.xlsx",
proxyURL: "//demos.telerik.com/kendo-ui/service/export",
filterable: true
excelExport: function(e) {
var sheet = e.workbook.sheets[0];
var rows = sheet.rows;
var rowIdx, colIdx, cells, cell;
for (rowIdx = 0; rowIdx < rows.length; rowIdx++) {
if (rows[rowIdx].type === "data") {
cells = rows[rowIdx].cells;
for (colIdx = sheet.freezePane.colSplit; colIdx < cells.length; colIdx++) {
cell = cells[colIdx];
cell.background = "#aabbcc";
cell.value = kendo.toString(cell.value, "c");
dataCellTemplate: $("dataCellTemplate").html(),
filterable: true,
sortable: true,
columnWidth: 200,
height: 580,
dataSource: {
type: "xmla",
columns: [{ name: "[Date].[Calendar]", expand: true }, { name: "[Product].[Category]" } ],
rows: [{ name: "[Geography].[City]" }],
measures: ["[Measures].[Reseller Freight Cost]"],
transport: {
connection: {
catalog: "Adventure Works DW 2008R2",
cube: "Adventure Works"
read: "//demos.telerik.com/olap/msmdpump.dll"
schema: {
type: "xmla"
error: function (e) {
alert("error: " + kendo.stringify(e.errors[0]));
}).data("kendoPivotGrid");
$("#export").click(function() {
pivotgrid.saveAsExcel();
</script>
</div>
30 小时
发表于 2021-4-23 14:35:10 | 显示全部楼层
Interesting stuff.
GMT+8, 2025-4-21 08:08
