查看: 5077|回复: 0
Kendo UI for jQuery:PivotGrid - 与Kendo UI Chart集成
发表于 2021-5-19 09:25:45 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R1 2021 SP2试用版下载
下面的示例演示如何将Kendo UI PivotGrid小部件与Kendo UI图表小部件集成。
[HTML] 纯文本查看 复制代码
<div id="example">
<div id="pivotgrid"></div>
<div id="chart"></div>
<script>
//function flatten the tree of tuples that datasource returns
function flattenTree(tuples) {
tuples = tuples.slice();
var result = [];
var tuple = tuples.shift();
var idx, length, spliceIndex, children, member;
while (tuple) {
//required for multiple measures
if(tuple.dataIndex !== undefined) {
result.push(tuple);
spliceIndex = 0;
for (idx = 0, length = tuple.members.length; idx < length; idx++) {
member = tuple.members[idx];
children = member.children;
if (member.measure) {
[].splice.apply(tuples, [0, 0].concat(expandMeasures(children, tuple)));
} else {
[].splice.apply(tuples, [spliceIndex, 0].concat(children));
spliceIndex += children.length;
return result;
function clone(tuple, dataIndex) {
var members = tuple.members.slice();
return {
dataIndex: dataIndex,
members: $.map(members, function(m) {
return $.extend({}, m, { children: [] });
function replaceLastMember(tuple, member) {
tuple.members[tuple.members.length - 1] = member;
return tuple;
function expandMeasures(measures, tuple) {
return $.map(measures, function(measure) {
return replaceLastMember(clone(tuple, measure.dataIndex), measure);
//Check whether the tuple has been collapsed
function isCollapsed(tuple, collapsed) {
var members = tuple.members;
for (var idx = 0, length = collapsed.length; idx < length; idx++) {
var collapsedPath = collapsed[idx];
if (indexOfPath(fullPath(members, collapsedPath.length -1), [collapsedPath]) !== -1) {
return true;
return false;
//Work with tuple names/captions
function indexOfPath(path, paths) {
var path = path.join(",");
for (var idx = 0; idx < paths.length; idx++) {
if (paths[idx].join(",") === path) {
return idx;
return -1;
function fullPath(members, idx) {
var path = [];
var parentName = members[idx].parentName;
idx -= 1;
while (idx > -1) {
path.push(members[idx].name);
idx -= 1;
path.push(parentName);
return path;
function memberCaption(member) { return member.caption };
function extractCaption(members) {
return $.map(members, memberCaption).join(" ");
function fullPathCaptionName(members, dLength, idx) {
var result = extractCaption(members.slice(0, idx + 1));
var measureName = extractCaption(members.slice(dLength, members.mLength));
if (measureName) {
result += " - " + measureName;
return result;
//the main function that convert PivotDataSource data into understandable for the Chart widget format
function convertData(dataSource, collapsed) {
var columnDimensionsLength = dataSource.columns().length;
var rowDimensionsLength = dataSource.rows().length;
var columnTuples = flattenTree(dataSource.axes().columns.tuples || [], collapsed.columns);
var rowTuples = flattenTree(dataSource.axes().rows.tuples || [], collapsed.rows);
var data = dataSource.data();
var rowTuple, columnTuple;
var idx = 0;
var result = [];
var columnsLength = columnTuples.length;
for (var i = 0; i < rowTuples.length; i++) {
rowTuple = rowTuples[i];
if (!isCollapsed(rowTuple, collapsed.rows)) {
for (var j = 0; j < columnsLength; j++) {
columnTuple = columnTuples[j];
if (!isCollapsed(columnTuple, collapsed.columns)) {
if (idx > columnsLength && idx % columnsLength !== 0) {
for (var ri = 0; ri < rowTuple.members.length; ri++) {
for (var ci = 0; ci < columnTuple.members.length; ci++) {
//do not add root tuple members, e.g. [CY 2005, All Employees]
//Add only children
if (!columnTuple.members[ci].parentName || !rowTuple.members[ri].parentName) {
continue;
result.push({
measure: Number(data[idx].value),
column: fullPathCaptionName(columnTuple.members, columnDimensionsLength, ci),
row: fullPathCaptionName(rowTuple.members, rowDimensionsLength, ri)
idx += 1;
return result;
</script>
<script>
var collapsed = {
columns: [],
rows: []
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
filterable: true,
//gather the collapsed members
collapseMember: function(e) {
var axis = collapsed[e.axis];
var path = e.path;
if (indexOfPath(path, axis) === -1) {
axis.push(path);
//gather the expanded members
expandMember: function(e) {
var index = indexOfPath(e.path, axis);
if (index !== -1) {
axis.splice(index, 1);
columnWidth: 100,
height: 330,
dataSource: {
type: "xmla",
columns: [{ name: "[Date].[Calendar]", expand: true }, { name: "[Employee].[Gender]" }],
rows: [{ name: "[Product].[Category]", expand: true }],
measures: ["[Measures].[Reseller Freight Cost]", "[Measures].[Internet Order Quantity]"],
transport: {
connection: {
catalog: "Adventure Works DW 2008R2",
cube: "Adventure Works"
read: "https://demos.telerik.com/olap/msmdpump.dll"
schema: {
type: "xmla"
error: function (e) {
alert("error: " + kendo.stringify(e.errors[0]));
dataBound: function() {
//create/bind the chart widget
initChart(convertData(this.dataSource, collapsed));
}).data("kendoPivotGrid");
function initChart(data) {
var chart = $("#chart").data("kendoChart");
if (!chart) {
$("#chart").kendoChart({
dataSource: {
data: data,
group: "row"
series: [{
type: "column",
field: "measure",
name: "#= group.value # (category)",
categoryField: "column"
legend: {
position: "bottom"
categoryAxis: {
labels: {
rotation: 310
valueAxis: {
labels: {
format: "${0}"
dataBound: function(e) {
var categoryAxis = e.sender.options.categoryAxis;
if (categoryAxis && categoryAxis.categories) {
categoryAxis.categories.sort();
} else {
chart.dataSource.data(data);
</script>
</div>
GMT+8, 2025-4-3 06:05
