查看: 4337|回复: 0
Kendo UI for jQuery:ivotGrid - 访问MDX查询
发表于 2021-5-28 10:24:56 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R2 2021试用版下载
有时,您可能需要在Kendo UI PivotGrid中覆盖由DataSource生成的查询。
要实现此操作,请访问生成的MDX查询,如以下示例所示。
[HTML] 纯文本查看 复制代码
<div id="example">
<div id="pivotgrid"></div>
<script>
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
filterable: true,
columnWidth: 200,
height: 580,
dataSource: {
type: "xmla",
columns: [{ name: "[Date].[Calendar]", expand: true }, { name: "[Product].[Category]" } ],
rows: [{ name: "[Geography].[City]" }],
measures: ["[Measures].[Internet Sales Amount]"],
transport: {
connection: {
catalog: "Adventure Works DW 2008R2",
cube: "Adventure Works"
read: "https://demos.telerik.com/olap/msmdpump.dll",
parameterMap: function(options, type) {
var query = kendo.data.transports.xmla.fn.options.parameterMap(options, type);
//modify the query here if needed
return query;
schema: {
type: "xmla"
error: function (e) {
alert("error: " + kendo.stringify(e.errors[0]));
}).data("kendoPivotGrid");
</script>
</div>
GMT+8, 2025-4-2 02:55
