查看: 4171|回复: 0
Kendo UI for jQuery使用教程:PivotGrid - 向列轴添加维度
发表于 2021-6-3 09:37:02 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R2 2021试用版下载
下面的示例演示如何使用Kendo UI PivotGrid API向小部件的列轴添加新维度。
[HTML] 纯文本查看 复制代码
<div id="example">
<button id="add">Add "ProductName"</button>
<div id="pivotgrid"></div>
<script>
var pivotgrid = $("#pivotgrid").kendoPivotGrid({
columnWidth: 120,
height: 570,
dataSource: {
data: products,
schema: {
model: {
fields: {
ProductName: { type: "string" },
UnitPrice: { type: "number" },
UnitsInStock: { type: "number" },
Discontinued: { type: "boolean" },
CategoryName: { field: "Category.CategoryName" }
cube: {
dimensions: {
ProductName: { caption: "All Products" },
CategoryName: { caption: "All Categories" },
Discontinued: { caption: "Discontinued" }
measures: {
"Sum": { field: "UnitPrice", format: "{0:c}", aggregate: "sum" }
columns: [{ name: "CategoryName", expand: true }],
rows: [{ name: "Discontinued", expand: true }],
measures: ["Sum"]
}).data("kendoPivotGrid");
$("#add").click(function() {
var ds = pivotgrid.dataSource;
var columns = ds.columns();
columns.push("ProductName");
ds.columns(columns);
</script>
</div>
GMT+8, 2025-4-3 06:03
