查看: 4541|回复: 0
Kendo UI控件的透视网格可动态更改数据源,让web开发更简单
发表于 2021-6-8 10:29:03 | 显示全部楼层 |阅读模式
Kendo UI for jQuery R2 2021试用版下载
以下示例演示如何动态更改 Kendo UI PivotGrid 小部件的数据源。
[HTML] 纯文本查看 复制代码
<script src="https://demos.telerik.com/kendo-ui/content/shared/js/products.js"></script>
<div id="example">
<button id="change">Change DS</button>
<div id="pivotgrid"></div>
<script>
$("#pivotgrid").kendoPivotGrid({
columnWidth: 120,
height: 570,
dataSource: {
data: products,
schema: {
model: {
fields: {
ProductName: { type: "string" },
UnitPrice: { type: "number" },
UnitsInStock: { type: "number" },
Discontinued: { type: "boolean" },
CategoryName: { field: "Category.CategoryName" }
cube: {
dimensions: {
ProductName: { caption: "All Products" },
CategoryName: { caption: "All Categories" },
Discontinued: { caption: "Discontinued" }
measures: {
"Sum": { field: "UnitPrice", format: "{0:c}", aggregate: "sum" }
columns: [{ name: "CategoryName", expand: true }, { name: "ProductName" } ],
rows: [{ name: "Discontinued", expand: true }],
measures: ["Sum"]
$("#change").click(function() {
var newDS = new kendo.data.PivotDataSource({
data: products,
schema: {
model: {
fields: {
cube: {
dimensions: {
measures: {
columns: [{ name: "Discontinued", expand: true }],
rows: [{ name: "CategoryName", expand: true }, { name: "ProductName" } ],
measures: ["Sum"]
$("#pivotgrid").data("kendoPivotGrid").setDataSource(newDS);
</script>
</div>
GMT+8, 2025-4-3 06:06
