查看: 5589|回复: 3
Gridcontrol控件选中多行数据自动弹出统计信息
11 小时
发表于 2021-7-6 12:34:40 | 显示全部楼层 |阅读模式
Gridcontrol控件选中多行数值,右下角弹出统计信息这种效果要怎么实现
发表于 2022-9-14 15:05:52 | 显示全部楼层
同问,解决了没?
56 小时
发表于 2022-9-20 10:38:34 | 显示全部楼层
前段时间刚好实现了类似功能,代码如下
protected virtual void OrderGridView_SelectionChanged(object sender, SelectionChangedEventArgs e)
            GridView view = (GridView)sender;
            ToolTipControllerShowEventArgs args = toolTipController1.CreateShowArgs();
            args.ToolTip = GetSelectedRows(view);
            args.Title = "";
            toolTipController1.ShowHint(args);
        protected virtual string GetSelectedRows(GridView view)
            List<selectCellvalue> selectdata = new List<selectCellvalue>();
            string ret = "";
            int rowIndex = -1;
            if (view.OptionsSelection.MultiSelectMode == GridMultiSelectMode.CellSelect)
                foreach (GridCell cell in view.GetSelectedCells())
                    decimal res;
                    if (decimal.TryParse(view.GetRowCellDisplayText(cell.RowHandle, cell.Column),out res))
                        selectdata.Add(new selectCellvalue()
                            key = 1,
                            value = Convert.ToDecimal(view.GetRowCellDisplayText(cell.RowHandle, cell.Column))
                    rowIndex = cell.RowHandle;
                if (selectdata.Count > 0)
                    ret = $"总和:" + selectdata.Sum(x => x.value);
                    ret += $"{Environment.NewLine}最小值:" + selectdata.Min(x => x.value);
                    ret += $"{Environment.NewLine}最大值:" + selectdata.Max(x => x.value);
                    ret += $"{Environment.NewLine}平均值:" + Math.Round( selectdata.Average(x => x.value),2);
                    ret += $"{Environment.NewLine}个数:" + selectdata.Count;
            return ret;
发表于 2023-1-6 22:07:55 | 显示全部楼层
比其他線上娛樂城更容易贏錢,所以也就是為甚麼這麼多人會選擇線上老虎機的原因
GMT+8, 2025-4-20 20:37
