- 回帖
- 162
- 3712
- 381 小时
- 2013-7-5
[free][/free]C# Code:
static class Program
/// The main entry point for the application.
[STAThread]
static void Main()
Application.EnableVisualStyles();
Application.SetCompatibleTextRenderingDefault(false);
Application.ThreadException = new ThreadExceptionEventHandler(Application_ThreadException);//捕获系统所产生的异常。
Application.ThreadExit = new EventHandler(Application_ThreadExit);
#region 检查程序是否运行多实例
if (Program.IsRunInstance())//检查程序是否运行多实例
Msg.Warning("系统已经启动!");
Application.ExitThread();
Application.Exit();
return;
#endregion
Application.Run(new frmMonitor());//运行主窗体
static void Application_ThreadExit(object sender, EventArgs e)
if (mutex != null)
mutex.ReleaseMutex();
mutex = null;
private static Mutex mutex = null;
///检查程序是否运行多实例
public static bool IsRunInstance()
mutex = new Mutex(false, "指纹考勤系统");
if (!mutex.WaitOne(0, false))//如果返回false则mutex已经被另一个线程所拥有
mutex.Close();
mutex = null;
return true;
return false;
private static void Application_ThreadException(object sender, ThreadExceptionEventArgs e)
MonitorLog.AddLog(e.Exception.Message);//程序未知错误,写入日志
