查看: 2000|回复: 1
task 调用函数问题 求助大神
关注 [开发者网] 微信公众号认证
14 小时
发表于 2023-5-25 15:52:40 | 显示全部楼层 |阅读模式
    DataTable d1, d2, d3;
        private void button3_Click(object sender, EventArgs e)
            Task T1 = new Task(()=>getValue("1",d1));
            Task T2 = new Task(() => getValue("2", d2));
            Task T3 = new Task(() => getValue("3", d3));
            T1.Start();
            T2.Start();
            T3.Start();
            Task.WaitAll(T1,T2,T3);
            MessageBox.Show("ok");
        private void getValue(String V1,DataTable T)
            T = new DataTable();
            T.Columns.Add("A1");
            if (V1.Equals("1"))
               T.Rows.Add("1");
            if (V1.Equals("2"))
                T.Rows.Add("2");
            if (V1.Equals("3"))
                T.Rows.Add("3");
     为什么最后d1,d2,d3全等于null   ???????
402 小时
发表于 2023-5-29 22:42:06 | 显示全部楼层
尝试加上 out 修饰符试试?
    var T1 = new Task(() => getValue("1", out d1));
    var T2 = new Task(() => getValue("2", out d2));
    var T3 = new Task(() => getValue("3", out d3));
    T1.Start();
    T2.Start();
    T3.Start();
    Task.WaitAll(T1, T2, T3);
private void getValue(string V1, out DataTable T)
    switch (V1)
        case "1":
            T.Rows.Add("1");
            break;
        case "2":
            T.Rows.Add("2");
            break;
        case "3":
            T.Rows.Add("3");
            break;
GMT+8, 2025-4-6 05:25
