查看: 3483|回复: 1
Easily convert files into SQL databases with SQLizer
239 小时
发表于 2024-1-3 21:45:39 | 显示全部楼层 |阅读模式
How SQLizer works
SQLizer can read a variety of files and convert them into SQL scripts that import the data into a database. From data in those files it can generate the necessary SQL code for storing data in a MySQL, Microsoft SQL Server or PostgreSQL database. SQLizer can read the following types of file:
如果您觉得有用,我将不胜感激您的评论和喜欢
I would appreciate your comments and likes if you find it useful
239 小时
 楼主| 发表于 2024-4-14 15:55:13 | 显示全部楼层
我真的很失望。 该帖子已被查看超过 750 次,但尚未互动
I'm really disappointed. The post has been viewed over 750 times but has not been interacted with
GMT+8, 2026-3-1 07:06
