查看: 4675|回复: 4
Telerik Kendo UI Complete 2016.1.112 Commercial Edition
28 小时
发表于 2016-1-16 10:55:44 | 显示全部楼层 |阅读模式
http://pan.baidu.com/s/1kTYM6aV
Telerik Kendo UI Complete 2016.1.112 Commercial Edition | 159.0 MB
Kendo UI Complete 2016 - Everything for building web and mobile apps with HTML5 and JavaScript. Fast, light, complete: 70+ jQuery-based UI widgets in one powerful toolset. AngularJS integration, Bootstrap support, mobile controls, offline data solution.
Integrates Well with Others
- Get full support for AngularJS and Twitter Bootstrap out of the box, or use your favorite JavaScript framework.
- Use only what you need, without having to change allegiances.
Ultimate Performance with Minimum Resources
Fast and light. Every Kendo UI widget is rendered with the fastest possible mark-up to deliver ultimate JavaScript performance.
Mobile-Friendly and Responsive
Touch support, easy mobile rendering, responsive capabilities and integration with Bootstrap.
Built-In, Customizable Themes
Apply one of the 13 built-in themes, such as SAP Fiori theme or Material Design theme, or create a customized theme in seconds using the ThemeBuilder tool.
It’s Easy to Get Started, Give it a Try
- Download and copy the /js and /styles directories
- Include the Kendo UI JavaScript and CSS files Make sure the common CSS file is registered before the theme CSS file.
- Add an HTML element For instance an <input> tag.
- Initialize the Kendo UI Widget Call the kendoDatePicker jQuery plugin
Client-Side or Server-Side, We’ve Got You Covered
- The suite contains 70+ ASP.NET MVC components. Being modular, they enable you to use the client and server pieces independently or together and still benefit from all the richness and performance of HTML5.
- The 70+ widgets in Telerik UI for JSP are jQuery-based, 40+ of which come with server-side wrappers. You can use Java Server Pages (JSP) to build modern HTML5 web apps.
- Telerik UI for PHP contains 70+ jQuery-based UI widgets for building sites and mobile apps with JavaScript and HTML5, plus 40+ PHP server wrappers. Just use the wrappers as you code and they’ll render the JavaScript.
参与人数 4赞扬 +4 收起 理由
lanneret + 1 很给力
海洋饼干 + 1 很给力
fessicon + 1 很给力
阿力 + 1 Thanks
968 小时
发表于 2016-1-17 09:43:04 | 显示全部楼层
不错 谢谢分享
GMT+8, 2025-4-5 04:29
