查看: 4006|回复: 1
Telerik UI for PHP / JSP 2016.1.112 Commercial Edition
28 小时
发表于 2016-1-16 10:56:43 | 显示全部楼层 |阅读模式
http://pan.baidu.com/s/1getTwrT
Telerik UI for PHP / JSP 2016.1.112 Commercial Edition | 100.2 MB
Telerik UI for PHP - Powered by HTML5 and Kendo UI to build .fast and responsive PHP apps. Telerik UI for JSP Build modern HTML5 and JavaScript sites with JSP wrappers powered by Kendo UI. Telerik UI for PHP is a complete framework for building modern HTML5 web and mobile apps using PHP.
UI for PHP Key Features:
Complete Web Development Framework
Rich Views and Models With MVVM
UI for PHP provides a high-performance Model-View-ViewModel (MVVM) framework, which enables you to manage complex HTML and JavaScript UI with declarative bindings and two-way syncing between applications views and models.
Unmatched PHP Performance
Every aspect of Telerik UI for PHP has been built from the ground-up to deliver maximum performance.
UI Widgets With PHP Server Wrappers
Telerik UI for PHP contains 70+ jQuery-based UI widgets for building sites and mobile apps with JavaScript and HTML5 and 40+ PHP server wrappers
Responsive UI for Modern Apps
Telerik UI for PHP delivers a complete, responsive experience and brings you the features you need to deliver “responsive UI for modern apps."
Server- and Client-Side APIs
Telerik UI for PHP gives you complete control over the Web and DataViz widgets via complete server-side APIs.
Customize Themes
When the out-of-the-box themes are not enough, you can use the ThemeBuilder tool to quickly customize the base styles to perfectly match your site.
Great UX Across Devices and Browsers
Telerik UI for PHP uses a mix of techniques to enable some HTML5 features in older browsers, and fine-tuned graceful degradation for others.
Pixel-Perfect Themes for Your PHP Apps
Telerik UI for PHP widgets support themes and styling, via CSS. The framework includes 11 out-of-the-box themes: Black, Blue Opal, Default, Metro, Metro Black, Silver, Bootrap, Uniform, High Contrast, Moonlight and Flat UI.
UI for JSP Key Features:
Telerik UI for JSP includes a Model-View-ViewModel (MVVM) framework. It lets you write JSP code to generate widgets that seamlessly integrate with your server-side backend.
Complete Framework for Enterprise Apps
Telerik UI for JSP is a complete web development framework for building modern HTML5 applications.
Pixel-Perfect Themes for Enterprise Apps
Telerik UI for JSP widgets support themes and styling via CSS. The framework includes 11 enterprise-ready out-of-the-box themes: Black, Blue Opal, Default, Metro, Metro Black, Silver, Bootsrap, Uniform, High Contrast, Moonlight, and Flat UI.
Client and Server Pieces: Alone or Together
Telerik UI for JSP gives you complete control over the Web and DataViz widgets with complete server-side APIs.
Responsive Design for Enterprise Apps
Telerik UI for JSP delivers a complete, responsive experience, bringing you the features you need to create responsive UI for your modern enterprise Java applications.
UI Widgets With JSP Server Wrappers
Telerik UI for JSP contains 70+ jQuery-based UI widgets for building sites and mobile apps with JavaScript and HTML5 and 40+ JSP server wrappers
Seamless UX: Any Browser or Device
Telerik UI for JSP uses a variety of tactics to enable some HTML5 features in older browsers, and fine-tuned graceful degradation for others.
Ready for Touch - and Enterprise
The 40+ UI widgets provide full support for touchscreen devices so your Java application will function on a wide array of devices with varying input options.
High-Performance JSP Enterprise Applications
Every aspect of Telerik UI for JSP has been built from the ground-up to deliver maximum performance in your enterprise application.
microfenal + 1 很给力
103 小时
发表于 2016-3-4 14:47:02 | 显示全部楼层
多谢LZ分享,资源太好了
GMT+8, 2025-4-5 04:24
