- 0
- 8 小时
- 1
- 2013-12-1
- 5
- 2016-8-1
- 5
- 131
- 8 小时
- 2013-12-1
A Superior SNMP .NET Class Library
Simple Network Management Protocol (SNMP) components seamlessly integrate threaded communications, security, and encoding / decoding so you can quickly develop custom SNMP applications. This development tool requires fewer resources, provides more flexibility, and elicits code that is easy to re-use and maintain. See our Programming Primer for detailed instructions.
Why buy a component when Open Source C # libraries are just a click away (#SNMP and SNMP Sharp Net)?
Open Source documentation and sample projects are very limited, so SNMP novices need not apply
they are not organized as agent and manager classes, so you have to figure out how to put the pieces together
advanced features like MIB parsing and SNMPv3 engine caching are missing
why risk the success of your project on "free" software that's likely to cost you days of research, excessive code writing and unnecessary testing?
Respond to SNMP requests and send notifications
Agent component receives, decodes and responds to Get, GetBulk, Set requests
Create and send Trap and Inform messages
Create default responses from requests or build your own
Automatically updates agent variables and tables
Use standard and custom MIBs
Load and parse MIB files at design-time or run-time
MibNode definitions use OIDs to associate MIB file definitions with variable IIDs found in PDUs
Intrinsic support provided for standard SNMPv2 SMI MIBs
TreeView can be populated with parsed MIBs for easy viewing
Comprehensive Security
Security class provides seamless SNMPv3 integration
MD5, SHA authentication support
DES, Triple DES, AES128, AES192, AES256 encryption support
Interoperability
Compatible with CISCO, MG-Soft, NET-SNMP and other SNMP software
Compatible with FIPS 140-2 standards
Complies with SNMP RFCs for version 1 (1155, 1156, 1157, 1212, 1213, 1215, 2863, 3418), version 2 (1901, 1907, 1908, 3416, 3417), and version 3 (3410, 3411, 3412, 3413 , 3414, 3415, 3416, 3417, 3418, 3584, 3826, 5343)
Instructions:
Use the dlls directly in VS
or
Install and replace the dlls.
The dll fix is for .net 4.0 / .net 2.0 only for now.
Alternate torrent download:
https://kat.cr/powersnmp-for-net-4-8-1-0-fix-t12038643.html
Note: Please seed!. Thanks
