查看: 17240|回复: 0
XPO 获取数据库服务器时间
787 小时
发表于 2016-5-8 12:03:16 | 显示全部楼层 |阅读模式
在开始学习XPO时,需要连接到数据库且需要获得数据库服务器时间,连接ORACLE
Session.DefaultSession.Connection = new OracleConnection("Data Source=dbserver;User ID=system;Password=oracle");
            Session.DefaultSession.AutoCreateOption = AutoCreateOption.SchemaOnly;
            Session.DefaultSession.Connect();
读取服务器时间:
public static  class oracleGetsysDate {
        public static  DateTime sysDate()
             System.Data.IDbCommand command;
            //System.Data.IDataReader reader;
            command = DevExpress.Xpo.Session.DefaultSession.Connection.CreateCommand();
            command.CommandText = "Select sysdate from dual";
            //reader = command.ExecuteReader();
            string dtm = command.ExecuteScalar().ToString();
            DateTime jtdtm = DateTime.Parse(dtm);
            return jtdtm;
调用:
  DateTime dt = oracleGetsysDate.sysDate().Date;
XPO的业务类:
public class TEST : XPLiteObject
        string fDEPT_CODE;
        [Key]
        [Size(10)]
        [DbType("varchar2(30)")][Persistent("Dept_code")][DisplayName("科室代码")]
        public string DEPT_CODE
            get { return fDEPT_CODE; }
            set { SetPropertyValue<string>("DEPT_CODE", ref fDEPT_CODE, value); }
        string fDEPT_NAME;
        [Size(30)]
        public string DEPT_NAME
            get { return fDEPT_NAME; }
            set { SetPropertyValue<string>("DEPT_NAME", ref fDEPT_NAME, value); }
        DateTime fCREATEDATE;
        public DateTime CREATEDATE
            get { return fCREATEDATE; }
            set {
                SetPropertyValue<DateTime>("CREATEDATE", ref fCREATEDATE, value); }
        public TEST(Session session) : base(session) { }
        public TEST() : base(Session.DefaultSession) { }
        public override void AfterConstruction() { base.AfterConstruction(); }
        protected override void OnSaving()
            base.OnSaving();
            if (!IsDeleted)
                UnitOfWork uw = new UnitOfWork();
                if (fDEPT_CODE == null || fDEPT_CODE == "")
                    throw new Exception("科室代码不能置空值,保存失败!");
        protected override void Spoil(bool disposing)
            base.Spoil(disposing);
调用XPO:
  try
                dbserver.TEST test = new TEST();
                test.DEPT_CODE = "123";
                test.DEPT_NAME = "Test2";
                test.CREATEDATE = dt;
                test.Save();
               // DateTime dt = oracleGetsysDate.sysDate();
                //this.textBox1.Text = dt.ToString();//得到查询表的第一行第一列
            catch (Exception ex)
                MessageBox.Show(ex.Message,"提示");
GMT+8, 2025-4-4 12:24
