查看: 4295|回复: 0
[源码] Java、C#双语版配套AES加解密示例
4518 小时
黄马甲
发表于 2016-6-1 15:12:12 | 显示全部楼层 |阅读模式
采用的加解密使用base64转码方法,ECB模式,PKCS5Padding填充,密码必须是16位,否则会报错
模式:Java的ECB对应C#的System.Security.Cryptography.CipherMode.ECB
填充方法:Java的PKCS5Padding对应C#System.Security.Cryptography.PaddingMode.PKCS7
Java和C#版的加解密是互通的,也就是能相互加解密,编码明确指定了采用UTF-8,有需要其他编码方法的请自行扩展
C#版
using System;
using System.Security.Cryptography;
using System.Text;
namespace CSharp.Util.Security
        ///  AES 加密
        /// <param name="str"></param>
        /// <param name="key"></param>
        /// <returns></returns>
        public static string AesEncrypt(string str, string key)
            if (string.IsNullOrEmpty(str)) return null;
            Byte[] toEncryptArray = Encoding.UTF8.GetBytes(str);
            System.Security.Cryptography.RijndaelManaged rm = new System.Security.Cryptography.RijndaelManaged
                Key = Encoding.UTF8.GetBytes(key),
                Mode = System.Security.Cryptography.CipherMode.ECB,
                Padding = System.Security.Cryptography.PaddingMode.PKCS7
            System.Security.Cryptography.ICryptoTransform cTransform = rm.CreateEncryptor();
            Byte[] resultArray = cTransform.TransformFinalBlock(toEncryptArray, 0, toEncryptArray.Length);
            return Convert.ToBase64String(resultArray, 0, resultArray.Length);
        ///  AES 解密
        public static string AesDecrypt(string str, string key)
            Byte[] toEncryptArray = Convert.FromBase64String(str);
            System.Security.Cryptography.ICryptoTransform cTransform = rm.CreateDecryptor();
            return Encoding.UTF8.GetString(resultArray);
JAVA版
[Java] 纯文本查看 复制代码
package nb.tmall.util;
import java.security.NoSuchAlgorithmException;
import java.security.SecureRandom;
import javax.crypto.*;
import javax.crypto.spec.SecretKeySpec;
import sun.misc.*;
@SuppressWarnings("restriction")
public class EncryptUtil {
    public static String aesEncrypt(String str, String key) throws Exception {
        if (str == null || key == null) return null;
        Cipher cipher = Cipher.getInstance("AES/ECB/PKCS5Padding");
        cipher.init(Cipher.ENCRYPT_MODE, new SecretKeySpec(key.getBytes("utf-8"), "AES"));
        byte[] bytes = cipher.doFinal(str.getBytes("utf-8"));
        return new BASE64Encoder().encode(bytes);
    public static String aesDecrypt(String str, String key) throws Exception {
        cipher.init(Cipher.DECRYPT_MODE, new SecretKeySpec(key.getBytes("utf-8"), "AES"));
        byte[] bytes = new BASE64Decoder().decodeBuffer(str);
        bytes = cipher.doFinal(bytes);
        return new String(bytes, "utf-8");
seamone + 1 很给力
GMT+8, 2025-4-21 03:35
