查看: 5660|回复: 5
Eziriz.NET.Reactor.v4.6.0.0破解版
1057 小时
发表于 2013-7-20 10:58:06 | 显示全部楼层 |阅读模式
OVERVIEW
NET Reactor is a powerful .NET codeprotection & licensing system which assists developersin protecting their .NET software. Developers are able to protecttheir software in a safe and simple way now. This way developerscan focus more on development than on worrying how to protect theirintellectual property.
http://www.eziriz.com/
WHAT'S NEW :
- [+] Added cross assembly obfuscation (public type obfuscation for referenced libraries)
- [+] Full protection support for Windows 8 WinRT (Store/Metro/Modern) assemblies
- [+] Full protection support for Windows Phone 8 assemblies
- [+] Improved Silverlight 5 protection
- [+] Improved 'Anti ILDASM' protection (to break decompiler)
- [+] Added 'Inject Invalid Opcode' option (available as sub option for 'Anti ILDASM')
- [+] Improved Visual Studio Add-in
- [+] Improved performance of protected assemblies
- [!] Fixed 'PreJIT Methods" issue
- [!] Fixed 'Resource Encryption' issue
- [!] Fixed Visual Studio 2012 Add-in issue
- [!] Fixed NecroBit issue on x86 compiled assemblies
- [!] Fixed issue affecting the combination 'NecroBit' and 'Embed Assemblies'
- [!] Fixed issue for Silverlight 5 (referencing multiple versions of the same assembly)
- [!] Fixed issue for relative paths defined via Command-line
- [!] Fixed digital code signing problem on Windows 8
- [!] Fixed WPF problem on "Native EXE File" protected applications
- [!] Fixed minor Bugs
综述
NET的反应堆是一个强大的NET codeprotection的许可制度,这协助developersin的保护。NET软件。开发人员能够在安全和简单的方式,现在protecttheir软件。这样developerscan更专心于开发令人担忧的如何保护theirintellectual的财产。
新增功能:
- [+]增加交叉装配混淆(公共类型混淆为引用的库)
- [+]支持全保护为Windows 8的WinRT(商店/地铁/现代)组件
- [+]为Windows Phone8支持全保护组件
- [+]改进的Silverlight5的保护
- [+]改进反ILDASM保护(突破反编译)
- [+]增加注入的无效操作“选项(可作为子选项为”反ILDASM)
- [+]改进Visual Studio中添加
- [+]改进性能的保护组件
- [!]固定'PreJIT的方法“的问题
- [!]修正“资源加密的问题
- [!]固定的Visual Studio2012新增发行
- [!]的固定NecroBit问题在x86编译的程序集
- [!]修正问题,影响组合的NecroBit“和”嵌入组件“
- [!]固定的问题,为Silverlight5(引用多个版本相同组件)
- [!]修正通过命令行定义为相对路径问题
- [!]固定数字代码签名在Windows 8上的问题
- [!]固定WPF问题上“母语EXE文件”保护的应用程序
- [!]固定小错误
密码:RecafedsHtsRRdgFTYgsd
http://pan.baidu.com/share/link?shareid=1117030377&uk=2251673388
喜欢的话就赞一个哈~
参与人数 3赞扬 +3 收起 理由
zqzgq + 1 Thanks
tomexou + 1 感谢分享,测试后可正常使用
lhmlyx2723356 + 1 Thanks
62 小时
发表于 2013-7-20 11:13:10 | 显示全部楼层
已经发布过了,Free的。
http://www.dxper.net/thread-339-1-2.html
1057 小时
 楼主| 发表于 2013-7-20 11:14:28 | 显示全部楼层
自己删不掉,等管理员删吧。去掉售价了。
1057 小时
 楼主| 发表于 2013-7-20 11:18:37 | 显示全部楼层
tch 发表于 2013-7-20 11:13
已经发布过了,Free的。
论坛的搜索好像不大好用,发布之前没搜索到。
36 小时
发表于 2013-10-18 10:40:37 | 显示全部楼层
太NB了,楼主辛苦了
GMT+8, 2025-4-2 02:30
