- 29
- 11 小时
- 0
- 2014-7-30
- 39
- 2022-3-26
- 39
- 209
- 11 小时
- 2014-7-30
发表于 2019-4-30 21:49:07
显示全部楼层
Ngen is running in the background in random times and messes up the DevExpress Assemblies so the Dimaster's crack for Visual Studio 2017 + DevExpress 18.2.5 (or newer) gets broken and the nag screen shows trial And not "registered".
to fix that some Folders with random names must be deleted from the assemply GAC folder of your windows and the tasks that are running in the background needed to be disable or deleted.
使用环境
Visual Studio 2017 v15.9.6
DevExpress v18.2.5
Dimaster v8.0 2017 Edition
注意:18.2.5及以上版本才需要这个补丁,低于18.2.5的不需要这个补丁。
Dimaster v8.0 的补丁论坛里自己找,到处都是了。
使用补丁后,删掉解决方案里原来的licx文件,并且重新生成解决方案。
下载地址
链接:https://pan.baidu.com/s/1cwgm9DcHACP2Qm2lRS2s2A
提取码:回复可见
本帖隐藏的内容
提取码:64vx 压缩包密码:123456 |
