- 0
- 3 小时
- 1
- 2016-10-10
- 5
- 2016-10-24
- 5
- 96
- 3 小时
- 2016-10-10
gridcontrol控件添加数据源之后,显示用户无法登陆,下面是详细信息
有关调用实时(JIT)调试而不是此对话框的详细信息,
请参见此消息的结尾。
************** 异常文本 **************
System.Data.SqlClient.SqlException (0x80131904): 用户 'sa' 登录失败。
在 System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
在 System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
在 System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
在 System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
在 System.Data.SqlClient.SqlInternalConnectionTds.CompleteLogin(Boolean enlistOK)
在 System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, SecureString newSecurePassword, Boolean ignoreSniOpenTimeout, TimeoutTimer timeout, Boolean withFailover)
在 System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(ServerInfo serverInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString connectionOptions, SqlCredential credential, TimeoutTimer timeout)
在 System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(TimeoutTimer timeout, SqlConnectionString connectionOptions, SqlCredential credential, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance)
在 System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, SqlCredential credential, Object providerInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString userConnectionOptions)
在 System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
在 System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnectionPool pool, DbConnectionOptions options, DbConnectionPoolKey poolKey, DbConnectionOptions userOptions)
在 System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnectionOptions userOptions)
在 System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnectionOptions userOptions)
在 System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
在 System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
在 System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
在 System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
在 System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
在 System.Data.SqlClient.SqlConnection.Open()
在 System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
在 System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
在 System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
在 Text.BookShopPlus2DataSet1TableAdapters.UsersTableAdapter.Fill(UsersDataTable dataTable) 位置 c:\Users\Administrator\Desktop\新建文件夹 (3)\Dex测试\WF01\Text\BookShopPlus2DataSet1.Designer.cs:行号 1172
在 Text.Form1.Form1_Load(Object sender, EventArgs e) 位置 c:\Users\Administrator\Desktop\新建文件夹 (3)\Dex测试\WF01\Text\Form1.cs:行号 22
在 System.Windows.Forms.Form.OnLoad(EventArgs e)
在 DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
在 System.Windows.Forms.Form.OnCreateControl()
在 System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
在 System.Windows.Forms.Control.CreateControl()
在 System.Windows.Forms.Control.WmShowWindow(Message& m)
在 System.Windows.Forms.Control.WndProc(Message& m)
在 System.Windows.Forms.ScrollableControl.WndProc(Message& m)
在 System.Windows.Forms.ContainerControl.WndProc(Message& m)
在 System.Windows.Forms.Form.WmShowWindow(Message& m)
在 System.Windows.Forms.Form.WndProc(Message& m)
在 DevExpress.XtraEditors.XtraForm.WndProc(Message& msg)
在 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
在 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
在 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
ClientConnectionId:7f18193d-5543-4bfc-add6-19fa2799d357
************** 已加载的程序集 **************
mscorlib
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.18063 built by: FX45RTMGDR
基本代码: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Text
程序集版本: 1.0.0.0
Win32 版本: 1.0.0.0
基本代码: file:///C:/Users/Administrator/Desktop/%E6%96%B0%E5%BB%BA%E6%96%87%E4%BB%B6%E5%A4%B9%20(3)/Dex%E6%B5%8B%E8%AF%95/WF01/Text/bin/Debug/Text.exe
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.18021 built by: FX45RTMGDR
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.34285 built by: FX452RTMGDR
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
DevExpress.BonusSkins.v15.2
程序集版本: 15.2.9.0
Win32 版本: 15.2.9.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.BonusSkins.v15.2/v4.0_15.2.9.0__b88d1754d700e49a/DevExpress.BonusSkins.v15.2.dll
DevExpress.Utils.v15.2
程序集版本: 15.2.9.0
Win32 版本: 15.2.9.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Utils.v15.2/v4.0_15.2.9.0__b88d1754d700e49a/DevExpress.Utils.v15.2.dll
DevExpress.Data.v15.2
程序集版本: 15.2.9.0
Win32 版本: 15.2.9.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Data.v15.2/v4.0_15.2.9.0__b88d1754d700e49a/DevExpress.Data.v15.2.dll
System.Configuration
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.18060 built by: FX45RTMGDR
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.34283 built by: FX452RTMGDR
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
程序集版本: 4.0.0.0
Win32 版本: 4.0.30319.17929 built by: FX45RTMREL
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/mscorlib.resources.dll
DevExpress.XtraGrid.v15.2
程序集版本: 15.2.9.0
Win32 版本: 15.2.9.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraGrid.v15.2/v4.0_15.2.9.0__b88d1754d700e49a/DevExpress.XtraGrid.v15.2.dll
DevExpress.XtraEditors.v15.2
程序集版本: 15.2.9.0
Win32 版本: 15.2.9.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraEditors.v15.2/v4.0_15.2.9.0__b88d1754d700e49a/DevExpress.XtraEditors.v15.2.dll
System.Data
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.ComponentModel.DataAnnotations
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Data.DataSetExtensions
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Numerics
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Transactions
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Windows.Forms.resources
程序集版本: 4.0.0.0
基本代码: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT 调试 **************
要启用实时(JIT)调试,
该应用程序或计算机的 .config 文件(machine.config)的 system.windows.forms 节中必须设置
jitDebugging 值。
编译应用程序时还必须启用
调试。
例如:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
启用 JIT 调试后,任何未经处理的异常
都将被发送到在此计算机上注册的 JIT 调试器,
而不是由此对话框处理。
求教各位,这个问题怎么解决
