- 8
- 4 小时
- 4
- 2013-7-24
- 22
- 2013-8-13
- 22
- 101
- 4 小时
- 2013-7-24
SQL 行变列(学生成绩问题)
CREATE TABLE [Test] (
[id] [int] IDENTITY (1, 1) NOT NULL ,
[name] [nvarchar] (50) COLLATE Chinese_PRC_CI_AS NULL ,
[subject] [nvarchar] (50) COLLATE Chinese_PRC_CI_AS NULL ,
[Source] [numeric](18, 0) NULL
) ON [PRIMARY]
GO
INSERT INTO [test] ([name],[subject],[Source]) values (N'张三',N'语文',60)
INSERT INTO [test] ([name],[subject],[Source]) values (N'李四',N'数学',70)
INSERT INTO [test] ([name],[subject],[Source]) values (N'王五',N'英语',80)
INSERT INTO [test] ([name],[subject],[Source]) values (N'王五',N'数学',75)
INSERT INTO [test] ([name],[subject],[Source]) values (N'王五',N'语文',57)
INSERT INTO [test] ([name],[subject],[Source]) values (N'李四',N'语文',80)
INSERT INTO [test] ([name],[subject],[Source]) values (N'张三',N'英语',100)
Go
--交叉表语句的实现:
--用于:交叉表的列数是确定的
select name,sum(case subject when '数学' then source else 0 end) as '数学',
sum(case subject when '英语' then source else 0 end) as '英语',
sum(case subject when '语文' then source else 0 end) as '语文'
from test
group by name
--用于:交叉表的列数是不确定的
declare @sql varchar(8000)
set @sql = 'select name,'
select @sql = @sql + 'sum(case subject when '''+subject+'''
then source else 0 end) as '''+subject+''','
from (select distinct subject from test) as a
select @sql
select @sql = left(@sql,len(@sql)-1) + ' from test group by name'
select @sql
exec(@sql)
go
