- 0
- 5 小时
- 29
- 2017-5-31
- 32
- 2017-6-12
- 32
- 151
- 5 小时
- 2017-5-31
[root@localhost conf]# ls
configuration.xsl log4j.properties zoo.cfg zoo_sample.cfg
7. 修改zoo.cfg文件
tickTime=2000
initLimit=10
syncLimit=5
# example sakes.
dataDir=/zookeeper/zkdata
clientPort=2181
#maxClientCnxns=60
#autopurge.snapRetainCount=3
#autopurge.purgeInterval=1
10. myid文件写入service2、service3
echo 2 > myid
echo 3 > myid
11.查看zk命令:
[root@localhost bin]# ls
README.txt zkCleanup.sh zkCli.cmd zkCli.sh zkEnv.cmd zkEnv.sh zkServer.cmd zkServer.sh zookeeper.out
12.执行zkServer.sh查看详细命令:
JMX enabled by default
14. jps查看zk进程
[root@localhost bin]# jps
31483 QuorumPeerMain
31664 Jps
Mode: follower
Mode: leader
16. 看到leader和follower节点已经安装成功
