查看: 3541|回复: 3
动态创建gridview,导出Excel数据
183 小时
发表于 2017-6-21 11:55:55 | 显示全部楼层 |阅读模式
先创建一个GridControl,在创建一个GridView视图,再传入数据
GridControl CreateGrid(List<marketinformation> pagemodel)
  GridControl grid = new GridControl(); ;
            GridView view = new GridView();
            grid.ViewCollection.Add(view);
            grid.MainView = view;
            view.GridControl = grid;
            foreach (GridColumn column in gridView2.Columns)
                DevExpress.XtraGrid.Columns.GridColumn gridColumnNumber = view.Columns.AddVisible(column.FieldName.ToString());
                gridColumnNumber.Caption = column.Caption.ToString();
                gridColumnNumber.FieldName = column.FieldName.ToString();
            grid.DataSource = pagemodel;
            this.Controls.Add(grid);//重要
            grid.ForceInitialize();//重要
            BestColumns(view);
            view.OptionsPrint.AutoWidth = false;
            return grid;        }
然后数据分页创建
IPrintable[] arr(List<marketinformation> data)
           List<IPrintable> Printable=new List<IPrintable>();
            int PageIndex=0;
            int PageSize=50000;
            int CurrentIndex=0;
            int TotalCount=data.Count;
            for(PageIndex=0;CurrentIndex<TotalCount;PageIndex++)
                var PageData = data.Skip(PageIndex*PageSize).Take(PageSize).ToList();
                Printable.Add(CreateGrid(PageData));
                CurrentIndex=(PageIndex+1)*PageSize;
            return Printable.ToArray();        }
最后数据多的时候自动列宽或假死,可以循环固定列宽,也可以写字段名
void BestColumns(GridView view)
         if (chkeds.Checked)
                view.OptionsView.ColumnAutoWidth = false;
                foreach (GridColumn column in view.Columns)
                    if (column.Visible)
                        switch (column.FieldName.ToString())
                            case "caccount":
                                view.Columns["caccount"].Width = 150;
                                break;
                            case "cunitname":
                                view.Columns["cunitname"].Width = 300;
                                break;
                            case "ddate":
                                view.Columns["ddate"].Width = 150;
                                break;
                            case "cemskind":
                                view.Columns["cemskind"].Width = 100;
                                break;
                            case "cnum":
                                view.Columns["cnum"].Width = 150;
                                break;
                            case "dsysdate":
                                view.Columns["dsysdate"].Width = 150;
                                break;
                            default:
                                view.Columns[column.FieldName].Width = 100;
                                break;
            else
                view.OptionsView.ColumnAutoWidth = true;
                    if (column.Visible)
                        view.Columns[column.FieldName].Width = 75;
22 小时
发表于 2017-6-26 11:26:10 | 显示全部楼层
看看是什么黑科技
28 小时
发表于 2017-6-27 09:32:49 | 显示全部楼层
谢谢楼主无私分享
GMT+8, 2025-4-19 18:04
