查看: 2336|回复: 0
JEESZ-Zookeeper集群安装
发表于 2017-8-23 08:55:52 | 显示全部楼层 |阅读模式
                     摘要: Zookeeper集群安装 SpringMVC+Mybatis, Dubbo+Zookeeper, java分布式架构
[root@localhost conf]# ls
7. 修改zoo.cfg文件
tickTime=2000
initLimit=10
syncLimit=5
# example sakes.
dataDir=/zookeeper/zkdata
clientPort=2181
#maxClientCnxns=60
#autopurge.snapRetainCount=3
#autopurge.purgeInterval=1
10. myid文件写入service2、service3
echo 2 > myid
echo 3 > myid
11.查看zk命令:
[root@localhost bin]# ls
12.执行zkServer.sh查看详细命令:
JMX enabled by default
14. jps查看zk进程
[root@localhost bin]# jps
31483 QuorumPeerMain
31664 Jps
Mode: follower
Mode: leader
16. 看到leader和follower节点已经安装成功
标签: SpringMVC+Mybatis, Dubbo+Zookeeper, java分布式架构
GMT+8, 2025-4-5 04:30
