本示例展示了如何把 XtraGrid 控件的默认资源 (English (美国) culture),替换为它们的等价符号。 例如, 你可以把在网格控件的自定义筛选对话框中使用的字符串 "equals",修改为数字等号 "=",如下所示:
private void Form1_Load(object sender, System.EventArgs e) { GridLocalizer.Active = new MyGridLocalizer(); } public class MyGridLocalizer : GridLocalizer { public override string GetLocalizedString(GridStringId id) { string ret = ""; switch(id) { // ... case GridStringId.CustomFilterDialogConditionEQU : return "="; case GridStringId.CustomFilterDialogConditionNEQ : return "<>"; case GridStringId.CustomFilterDialogConditionGT : return ">"; case GridStringId.CustomFilterDialogConditionGTE : return ">="; case GridStringId.CustomFilterDialogConditionLT : return "<"; case GridStringId.CustomFilterDialogConditionLTE : return "<="; // ... default: ret = ""; break; } return ret; } } |
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) _ Handles MyBase.Load GridLocalizer.Active = New MyGridLocalizer() End Sub Public Class MyGridLocalizer Inherits GridLocalizer Public Overrides Function GetLocalizedString(ByVal id As GridStringId) As String Dim ret As String = "" Select Case id ' ... Case GridStringId.CustomFilterDialogConditionEQU : Return "=" Case GridStringId.CustomFilterDialogConditionNEQ : Return "<>" Case GridStringId.CustomFilterDialogConditionGT : Return ">" Case GridStringId.CustomFilterDialogConditionGTE : Return ">=" Case GridStringId.CustomFilterDialogConditionLT : Return "<" Case GridStringId.CustomFilterDialogConditionLTE : Return "<=" ' ... Case Else ret = "" End Select Return ret End Function End Class |
结果显示如下:
要获得更多关于本地化的信息、以及关于本地化 DevExpress 组件必需的特定 Localizer 类的信息, 请参阅 本地化 DevExpress .NET Windows 窗体控件 文档。 |
