下面的示例展示了如何预览 XtraGrid 控件。
private void ShowGridPreview(DevExpress.XtraGrid.GridControl grid) { // Check whether the XtraGrid control can be previewed. if(!grid.IsPrintingAvailable) { MessageBox.Show("The 'DevExpress.XtraPrinting' Library is not found", "Error"); return; } // Opens the Preview window. grid.ShowPreview(); } |
Sub ShowGridPreview(ByVal grid As DevExpress.XtraGrid.GridControl) ' Check whether the XtraGrid control can be previewed. If Not grid.IsPrintingAvailable Then MessageBox.Show("The 'DevExpress.XtraPrinting' Library is not found", "Error") Return End If ' Opens the Preview window. grid.ShowPreview() End Sub |
下面的插图展示了示例网格控件的预览窗口。
