这个示例创建了一个修改编辑器文本大小写的自定义格式提供程序。 编辑器将遵照指定的格式字符串来显示文本 (FormatInfo.FormatString 属性值)。 这个字符串被作为格式参数传递到 Format 方法。 如果这个参数值是 'u',那么显示值被转换为大写; 如果这个格式字符串是 'l',那么显示值被转换为小写。
请参阅 自定义格式设置 主题,了解关于创建自定义格式提供程序的信息。
下面的插图展示了文本编辑器的、在执行示例代码之前和之后的外观。
// A custom formatter object. class CustomFormatter : IFormatProvider, ICustomFormatter{ // The GetFormat method of the IFormatProvider interface. // This must return an object that provides formatting services for the specified type. public object GetFormat(System.Type type){ return this; } // The Format method of the ICustomFormatter interface. // This must format the specified value according to the specified format settings. public string Format(string format, object arg, IFormatProvider formatProvider){ string formatValue = arg.ToString(); if (format == "u") return formatValue.ToUpper(); else if (format == "l") return formatValue.ToLower(); else return formatValue; } } // ... // Assign the custom formatter to the editors. textEdit1.Properties.DisplayFormat.FormatType = FormatType.Custom; textEdit1.Properties.DisplayFormat.FormatString = "u"; textEdit1.Properties.DisplayFormat.Format = new CustomFormatter(); textEdit2.Properties.DisplayFormat.FormatType = FormatType.Custom; textEdit2.Properties.DisplayFormat.FormatString = "l"; textEdit2.Properties.DisplayFormat.Format = new CustomFormatter(); |
' A custom formatter object. Class CustomFormatter : Implements IFormatProvider, ICustomFormatter ' The GetFormat method of the IFormatProvider interface. ' This must return an object that provides formatting services for the specified type. Public Function GetFormat(ByVal type As Type) As Object _ Implements IFormatProvider.GetFormat Return Me End Function ' The Format method of the ICustomFormatter interface. ' This must format the specified value according to the specified format settings. Public Function Format(ByVal formatString As String, ByVal arg As Object, _ ByVal formatProvider As IFormatProvider) As String Implements ICustomFormatter.Format Dim formatValue As String = arg.ToString() If (formatString = "u") Then Format = formatValue.ToUpper() ElseIf formatString = "l" Then Format = formatValue.ToLower() Else Format = formatValue End If End Function End Class ' ... ' Assign the custom formatter to the editors. TextEdit1.Properties.DisplayFormat.FormatType = FormatType.Custom TextEdit1.Properties.DisplayFormat.FormatString = "u" TextEdit1.Properties.DisplayFormat.Format = New CustomFormatter() TextEdit2.Properties.DisplayFormat.FormatType = FormatType.Custom TextEdit2.Properties.DisplayFormat.FormatString = "l" TextEdit2.Properties.DisplayFormat.Format = New CustomFormatter() |
