这个示例展示了如何隐藏 最终用户设计器 的属性网格中的某些属性。 要这样做,则接管 XtraReport.FilterControlProperties 静态事件,并为属性网格定义筛选规则。
例如,下列代码演示了如何隐藏 XRControl.Scripts 属性 (对所有报表元素隐藏)、SubreportBase.ReportSource 属性 (对所有子报表隐藏)、 XRControl.Name 和 XRControl.DataBindings 属性 (对特定标签隐藏)。
using DevExpress.XtraReports.UI; using DevExpress.XtraReports.UserDesigner; // ... static void Main() { // Handle the static FilterControlProperties event // to define filtering rules for the Property Grid. XtraReport.FilterControlProperties += new FilterControlPropertiesEventHandler(OnFilterControlProperties); Application.Run(new Form1()); } private void button1_Click(object sender, System.EventArgs e) { // Create a report of the XtraReport1 type and invoke its End-User Designer. XtraReport1 report = new XtraReport1(); report.ShowDesigner(); } static void OnFilterControlProperties(object sender, FilterControlPropertiesEventArgs e) { // If you wish to hide the scripting ability in the End-User Designer, // just remove the Scripts property for all report elements. e.Properties.Remove("Scripts"); // If you wish subreports to always show the predefined reports, // you may hide the ReportSource property. if (e.Control is XRSubreport) { e.Properties.Remove("ReportSource"); } // The following code hides the Name and DataBindings properties // for the xrLabel1 in XtraReport1. if (sender is XtraReport1 && e.Control.Name == "xrLabel1") { e.Properties.Remove("Name"); e.Properties.Remove("DataBindings"); } } | |
Imports DevExpress.XtraReports.UI Imports DevExpress.XtraReports.UserDesigner ' ... ' NOTE: To make this code work, set the "Startup object" option ' to "Sub Main" in the General properties of your project. <STAThread()> Shared Sub Main() ' Handle the static FilterControlProperties event ' to define filtering rules for the Property Grid. AddHandler XtraReport.FilterControlProperties, AddressOf OnFilterControlProperties Application.Run(New Form1()) End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) _ Handles Button1.Click ' Create a report of the XtraReport1 type and invoke its End-User Designer. Dim report As New XtraReport1() report.ShowDesigner() End Sub Shared Sub OnFilterControlProperties(ByVal sender As System.Object, ByVal e As _ FilterControlPropertiesEventArgs) ' If you wish to hide the scripting ability in the End-User Designer, ' just remove the Scripts property for all report elements. e.Properties.Remove("Scripts") ' If you wish subreports to always show the predefined reports, ' you may hide the ReportSource property. If TypeOf e.Control Is XRSubreport Then e.Properties.Remove("ReportSource") End If ' The following code hides the Name and DataBindings properties ' for the xrLabel1 in XtraReport1. If TypeOf sender Is XtraReport1 And e.Control.Name = "XrLabel1" Then e.Properties.Remove("Name") e.Properties.Remove("DataBindings") End If End Sub | |
