下面的示例演示了如何在运行时刻创建新空白报表 (XtraReport 类的实例),如何创建被绑定到 MDB 文件的数据对象 (通过 XtraReportBase.DataSource、XtraReportBase.DataAdapter 和 XtraReportBase.DataMember 属性),然后填充报表的 DetailBand(细节带区),此带区包含一个显示 MDB 文件中数据的 XRLabel 报表控件。
using System;
using System.Data;
using System.Data.OleDb;
using System.Windows.Forms;
using DevExpress.XtraReports.UI;
private void button1_Click(object sender, EventArgs e) {
XtraReport report = new XtraReport();
OleDbDataAdapter adapter = new OleDbDataAdapter("SELECT * FROM Categories",
@"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=..\..\nwind.mdb");
DataSet ds = new DataSet();
adapter.FillSchema(ds, SchemaType.Source);
report.DataSource = ds;
report.DataAdapter = adapter;
report.DataMember = "Table";
DetailBand detailBand = new DetailBand();
detailBand.Height = 50;
report.Bands.Add(detailBand);
XRLabel label = new XRLabel();
label.DataBindings.Add("Text", null, "CategoryName");
detailBand.Controls.Add(label);
report.ShowPreview();
Imports System
Imports System.Data
Imports System.Data.OleDb
Imports System.Windows.Forms
Imports DevExpress.XtraReports.UI
Private Sub button1_Click(ByVal sender As Object, ByVal e As EventArgs) _
Handles button1.Click
Dim report As New XtraReport()
Dim adapter As New OleDbDataAdapter("SELECT * FROM Categories", _
Dim ds As New DataSet()
Dim detailBand As New DetailBand()
Dim label As New XRLabel()
label.DataBindings.Add("Text", Nothing, "CategoryName")
参阅
