下面的示例演示了当报表被 导出为 HTML 时,如何使用 XRControl.HtmlItemCreated 事件来创建自定义 HTML 单元格。 下面的处理方法创建了两个 DevExpress.XtraPrinting.HtmlExport.Controls.DXHtmlTableCell 对象,用于在网页上显示一个复选框和一个超链接。
为了使此示例能正确工作,需执行下列操作。
添加新报表 (命名为 XtraReport1) 到应用程序中。
把 XRLabel 控件拖放到报表中,并以下列方式接管它的 HtmlItemCreated 事件:
C# 复制代码
using DevExpress.XtraReports.UI; using DevExpress.XtraPrinting.HtmlExport.Controls; using DevExpress.XtraPrinting.HtmlExport.Native; // ... private void xrLabel1_HtmlItemCreated(object sender, HtmlEventArgs e) { // Clear the contents of the parent html row. DXHtmlTableRow parentRow = (DXHtmlTableRow)e.ContentCell.Parent; parentRow.Controls.Clear(); // Create a check box cell. DXHtmlTableCell checkCell = new DXHtmlTableCell(); DXHtmlGenericControl checkBox1 = new DXHtmlGenericControl(DXHtmlTextWriterTag.Input); checkBox1.Attributes["checked"] = "true"; checkBox1.Attributes["type"] = "CheckBox"; checkCell.Controls.Add(checkBox1); // Create a hyperlink cell. DXHtmlTableCell linkCell = new DXHtmlTableCell(); DXHtmlAnchor hypLink = new DXHtmlAnchor(); hypLink.InnerText = "XtraReports Web Page"; hypLink.HRef = "http://www.devexpress.com/Products/NET/Reporting/index.xml"; linkCell.Controls.Add(hypLink); // Add the created cells to the parent row. parentRow.Cells.Add(checkCell); parentRow.Cells.Add(linkCell); }
Visual Basic 复制代码
Imports DevExpress.XtraReports.UI Imports DevExpress.XtraPrinting.HtmlExport.Controls Imports DevExpress.XtraPrinting.HtmlExport.Native ' ... Private Sub xrLabel1_HtmlItemCreated(ByVal sender As Object, ByVal e As HtmlEventArgs) _ Handles xrLabel1.HtmlItemCreated ' Clear the contents of the parent html row. Dim parentRow As DXHtmlTableRow = CType(e.ContentCell.Parent, DXHtmlTableRow) parentRow.Controls.Clear() ' Create a check box cell. Dim checkCell As New DXHtmlTableCell() Dim checkBox1 As New DXHtmlGenericControl(DXHtmlTextWriterTag.Input) checkBox1.Attributes("checked") = "true" checkBox1.Attributes("type") = "CheckBox" checkCell.Controls.Add(checkBox1) ' Create a hyperlink cell. Dim linkCell As New DXHtmlTableCell() Dim hypLink As New DXHtmlAnchor() hypLink.InnerText = "XtraReports Web Page" hypLink.HRef = "http://www.devexpress.com/Products/NET/Reporting/index.xml" linkCell.Controls.Add(hypLink) ' Add the created cells to the parent row. parentRow.Cells.Add(checkCell) parentRow.Cells.Add(linkCell) End Sub
然后,可以使用下列代码或类似于 把报表导出为 HTML。
using System; using System.Windows.Forms; using System.Diagnostics; // ... private void button1_Click(object sender, EventArgs e) { XtraReport1 report = new XtraReport1(); report.ExportToHtml("Test.html"); StartProcess("Test.html"); } public void StartProcess(string path) { Process process = new Process(); try { process.StartInfo.FileName = path; process.Start(); process.WaitForInputIdle(); } catch { } } |
Imports System Imports System.Windows.Forms Imports System.Diagnostics ' ... Private Sub button1_Click(ByVal sender As Object, ByVal e As EventArgs) _ Handles button1.Click Dim report As New XtraReport1() report.ExportToHtml("Test.html") StartProcess("Test.html") End Sub Public Sub StartProcess(ByVal path As String) Dim process As New Process() Try process.StartInfo.FileName = path process.Start() process.WaitForInputIdle() Catch End Try End Sub |
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E89。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
