下面的示例展示了如何创建一个有两个工具提示项的 SuperToolTip 对象。 其中第一个工具提示项将显示 "Edit Popup Menu" 字符串; 第二个工具提示项将包含一幅图片和 "Show the Edit popup menu" 文本:
- 将项显式添加到 SuperToolTip.Items 集合中;
- 使用 SuperToolTip.Setup 方法。
using DevExpress.Utils; // The component used to load images from a form's resources. System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(Form1)); // The image to display within a SuperTooltip. Image resImage = ((System.Drawing.Image)(resources.GetObject("resource.Image1"))); // Method 1 SuperToolTip sTooltip1 = new SuperToolTip(); // Create a tooltip item that represents a header. ToolTipTitleItem titleItem1 = new ToolTipTitleItem(); titleItem1.Text = "Edit Popup Menu"; // Create a tooltip item that represents the SuperTooltip's contents. ToolTipItem item1 = new ToolTipItem(); item1.Image = resImage; item1.Text = "Show the Edit popup menu"; // Add the tooltip items to the SuperTooltip. sTooltip1.Items.Add(titleItem1); sTooltip1.Items.Add(item1); // Method 2 SuperToolTip sTooltip2 = new SuperToolTip(); // Create an object to initialize the SuperToolTip. SuperToolTipSetupArgs args = new SuperToolTipSetupArgs(); args.Title.Text = "Edit Popup Menu"; args.Contents.Text = "Show the Edit popup menu"; args.Contents.Image = resImage; sTooltip2.Setup(args); |
Imports DevExpress.Utils ' The component used to load images from a form's resources. Dim resources As System.ComponentModel.ComponentResourceManager = _ New System.ComponentModel.ComponentResourceManager(GetType(Form1)) ' The image to display within a SuperTooltip. Dim resImage As Image = CType(resources.GetObject("resource.Image1"), System.Drawing.Image) ' Method 1 Dim sTooltip1 As SuperToolTip = New SuperToolTip ' Create a tooltip item that represents a header. Dim titleItem1 As ToolTipTitleItem = New ToolTipTitleItem titleItem1.Text = "Edit Popup Menu" ' Create a tooltip item that represents the SuperTooltip's contents. Dim item1 As ToolTipItem = New ToolTipItem item1.Image = resImage item1.Text = "Show the Edit popup menu" ' Add the tooltip items to the SuperTooltip. sTooltip1.Items.Add(titleItem1) sTooltip1.Items.Add(item1) ' Method 2 Dim sTooltip2 As SuperToolTip = New SuperToolTip ' Create an object to initialize the SuperToolTip. Dim args As SuperToolTipSetupArgs = New SuperToolTipSetupArgs args.Title.Text = "Edit Popup Menu" args.Contents.Text = "Show the Edit popup menu" args.Contents.Image = resImage sTooltip2.Setup(args) |
