CodeCentralShow Me
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E172。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。
下面的示例演示了如何使用 XtraReport.ExportOptions 属性,来指定在打印预览期间导出报表时的所有选项。 注意,在本例中,报表被静默导出,而不对最终用户作出任何提示。
 (Form1.cs)
using System;
using System.Windows.Forms;
using System.Text;
using System.Globalization;
using System.Drawing.Imaging;
using DevExpress.XtraPrinting;
namespace ExportOpts {
    public partial class Form1 : Form {
        public Form1() {
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e) {
            XtraReport1 report = new XtraReport1();
            report.CreateDocument();
            PrintingSystemBase printingSystem1 = report.PrintingSystem;
            // Obtain the current export options.
            ExportOptions options = printingSystem1.ExportOptions;
            // Set Print Preview options.
            options.PrintPreview.ActionAfterExport = ActionAfterExport.AskUser;
            options.PrintPreview.DefaultDirectory = "C:\\Temp";
            options.PrintPreview.DefaultFileName = "Report";
            options.PrintPreview.SaveMode = SaveMode.UsingDefaultPath;
            options.PrintPreview.ShowOptionsBeforeExport = false;
            // Set E-mail options.
            options.Email.RecipientAddress = "someone@somewhere.com";
            options.Email.RecipientName = "Someone";
            options.Email.Subject = "Test";
            options.Email.Body = "Test";
            // Set CSV-specific export options.
            options.Csv.Encoding = Encoding.Unicode;
            options.Csv.Separator =
                CultureInfo.CurrentCulture.TextInfo.ListSeparator.ToString();
            // Set HTML-specific export options.
            options.Html.CharacterSet = "UTF-8";
            options.Html.RemoveSecondarySymbols = false;
            options.Html.Title = "Test Title";
            // Set Image-specific export options.
            options.Image.Format = ImageFormat.Jpeg;
            // Set MHT-specific export options.
            options.Mht.CharacterSet = "UTF-8";
            options.Mht.RemoveSecondarySymbols = false;
            options.Mht.Title = "Test Title";
            // Set PDF-specific export options.
            options.Pdf.Compressed = true;
            options.Pdf.ImageQuality = PdfJpegImageQuality.Low;
            options.Pdf.NeverEmbeddedFonts = "Tahoma;Courier New";
            options.Pdf.DocumentOptions.Application = "Test Application";
            options.Pdf.DocumentOptions.Author = "Test Team";
            options.Pdf.DocumentOptions.Keywords = "Test1, Test2";
            options.Pdf.DocumentOptions.Subject = "Test Subject";
            options.Pdf.DocumentOptions.Title = "Test Title";
            // Set Text-specific export options.
            options.Text.Encoding = Encoding.Unicode;
            options.Text.Separator =
            // Set XLS-specific export options.
            options.Xls.ShowGridLines = true;
            options.Xls.SheetName = "Page 1";
            options.Xls.TextExportMode = TextExportMode.Value;
            // Set XLSX-specific export options.
            options.Xlsx.ShowGridLines = true;
            options.Xlsx.SheetName = "Page 1";
            options.Xlsx.TextExportMode = TextExportMode.Value;
            // Show the Print Preview form.
            report.ShowPreviewDialog();
 (Form1.vb)
Imports Microsoft.VisualBasic
Imports System
Imports System.Windows.Forms
Imports System.Text
Imports System.Globalization
Imports System.Drawing.Imaging
Imports DevExpress.XtraPrinting
Namespace ExportOpts
    Partial Public Class Form1
        Inherits Form
        Public Sub New()
        Private Sub button1_Click(ByVal sender As Object, ByVal e As EventArgs) Handles button1.Click
            Dim report As New XtraReport1()
            Dim printingSystem1 As PrintingSystem = report.PrintingSystem
            ' Obtain the current export options.
            Dim options As ExportOptions = printingSystem1.ExportOptions
            ' Set Print Preview options.
            options.PrintPreview.DefaultDirectory = "C:\Temp"
            options.PrintPreview.ShowOptionsBeforeExport = False
            ' Set E-mail options.
            ' Set CSV-specific export options.
            options.Csv.Separator = CultureInfo.CurrentCulture.TextInfo.ListSeparator.ToString()
            ' Set HTML-specific export options.
            options.Html.RemoveSecondarySymbols = False
            ' Set Image-specific export options.
            ' Set MHT-specific export options.
            options.Mht.RemoveSecondarySymbols = False
            ' Set PDF-specific export options.
            options.Pdf.Compressed = True
            ' Set Text-specific export options.
            options.Text.Separator = CultureInfo.CurrentCulture.TextInfo.ListSeparator.ToString()
            ' Set XLS-specific export options.
            options.Xls.ShowGridLines = True
            ' Set XLSX-specific export options.
            options.Xlsx.ShowGridLines = True
            ' Show the Print Preview form.
            printingSystem1.PreviewFormEx.ShowDialog()
    End Class
End Namespace
