这个示例展示了在运行时刻如何显示预填充数据源的 图表向导。 对于那些主要由最终用户来配置图表的应用程序而言,这是很有用的。
要在运行时刻运行图表向导,则应该使用 ChartWizard 对象的 ChartWizard.ShowDialog 方法。 下列代码演示了如何创建图表对象,把它绑定到数据源,然后通过向导让最终用户调整图表的设置,并显示含有图表的一个窗体。
using System.Windows.Forms;
using DevExpress.XtraCharts;
using DevExpress.XtraCharts.Wizard;
// Create a chart.
ChartControl chart = new ChartControl();
// Set its data source.
// You can set any other specific options for the chart here.
chart.DataSource = dataSet11;
// Create a ChartWizard for a new ChartControl
ChartWizard wiz = new ChartWizard(chart);
// Invoke the chart's wizard.
wiz.ShowDialog();
// Create a form, add the chart to it, and display the form.
Form form = new Form();
form.Controls.Add(chart);
form.Show();
Imports System.Windows.Forms
Imports DevExpress.XtraCharts
Imports DevExpress.XtraCharts.Wizard
' Create a chart
Dim chart As ChartControl = New ChartControl
' Set its data source.
' You can set any other specific options for the chart here.
' Create a ChartWizard for a new ChartControl
Dim wiz As ChartWizard = New ChartWizard(chart)
' Invoke the chart's wizard.
wiz.ShowDialog
' Create a form, add the chart to it, and display the form.
Dim form As Form = New Form
form.Show
